[solved] LE + DuckDNS: SSL_ERROR_RX_RECORD_TOO_LONG
Hi all
I have installed LE & DuckDNS on Home Assistant OS (2020.12.0) and everything seems OK.
On the router, I have forwarded tcp 443 to 8123 which is reported as open.
When I try to connect from a browser on a remote LAN with https://.duckdns.org I get the following error message:
Any idea what might be wrong?
Same here with add-on Duckdns alone ( without LE )
http://192.168.1.92:8123/hassio/addon/core_duckdns/documentation
Browser is Firefox
Secure Connection Failed
An error occurred during a connection to xxxx9.duckdns.org:443. SSL received a record that exceeded the maximum permissible length.
Error code: SSL_ERROR_RX_RECORD_TOO_LONG
    The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Anyone?
Forgot to mention that I mainly use FF but Chromium gives:
ERR_SSL_PROTOCOL_ERROR
With the Android mobile app 3.0.2 minimal I also get
For anyone bumping on this: the reason for my problem was because I forgot to enter the http integration in my configuration.yaml
http:
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
@gerardsamara: maybe this solves your problem…
Thanks @Nick4 for the proposal.
When i enter the http integration in the configuration file , I cannot reconnect to HA after HA reset .
I had to connect via SSH and manually remove the http integration in configuration.yaml file.
In the Duckdns addon documentation this http integration is included , so is it really needed when using Duckdns addon alone ( without Let’sEncrypt addon) ?
The Duckdns addon log looks ok at start
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[09:45:37] INFO: OK
xxx.177.102.213
NOCHANGE
Processing xxxx.duckdns.org
 + Checking domain name(s) of existing cert... unchanged.
 + Checking expire date of existing cert...
 + Valid till Mar 12 16:20:18 2021 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
[09:50:49] INFO: OK
xxx.177.102.213
NOCHANGE
[09:55:50] INFO: OK
xxx.177.102.213
NOCHANGE
With the HA Android application i got also
Without Let’s Encrypt, you have to use port 8123 (both WAN & LAN) AND specify the port when connecting, being
http://yoursubdomain.duckdns.org:8123
Any particular reason for not using LE?
Thanks for the setup. … no progress so I will try now LE+Duckdns
Hi Nick4,
Sorry to bother you but as per the Duckdns add-on … http://192.168.1.xx:8123/hassio/addon/core_duckdns/documentation , sounds like you are just overwriting the default value ( post #4 )
Additionally, you'll need to configure the Home Assistant Core to pick up the SSL certificates. This is done by setting the following configuration for the HTTP integration configuration in your configuration.yaml:
http:
Option lets_encrypt.certfile
The name of the certificate file generated by Let's Encrypt. The file is used for SSL by Home Assistant add-ons and is recommended to keep the filename as-is (fullchain.pem) for compatibility.
Note: The file is stored in /ssl/, which is the default for Home Assistant
Option lets_encrypt.keyfile
The name of the private key file generated by Let's Encrypt. The private key file is used for SSL by Home Assistant add-ons and is recommended to keep the filename as-is (privkey.pem) for compatibility.
==>> I am not sure about what i am saying but this is what i understand from the doc.
Hi @gerardsamara, no problem.
What do you mean by “overwriting”?
I have configured it with the documentation from the duckdns add-on and it works.
FYI: the link to the documentation that you provide is on your LAN so nobody can open that.
For the link to the documentation , it can be accessed from the documentation tab of the Duckdns addon as you said , i did not found other link from the documentation.
For the overwriting point :
In the duckdns and Letsencrypt addons , their configuration file contains both
certfile: fullchain.pem
keyfile: privkey.pem
Which is the default files as per the duckdns addon file
So adding the http part in configuration.yaml file is doing the same if the sytem is behaving properly
http:
==>> Hope this is clear and that i have correctly interpreted the documentation.!
==>> Here I may have a problem as the http part in configuration file prevents HA to restart !
Sorry, still don’t get your point about the certificate issue.
Are you sure HA is not restarting!?
It’s not becoming any easier by using multiple, different topics…
EDIT: you also have to be aware that some modem/routers don’t support NAT loopback, so you cannot connect to your own network being on your LAN as if you connect from the internet.
@Nick4 ,
Thanks for your reply.
You are right , in order to don’t hijack your (solved) post , I have created a new topic
