[SOLVED] Lets Encrypt Certificate Invalid (Not using Duck DNS)
I wonder if someone could help me, i am having major problems with my Lets Encrypt certificate.
It was working fine the first time i used it but since the first renewal it has not worked since.
I am not sure whether its because of the system updates of my HASS.IO install or whether its because i have a config error but either way its a pain as i cant use the HA app on my devices because of the invlaid cert.
Lets Encrypt Config
  "email": "[email protected]",
  "domains": [
    "ha.domain.com"
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem"
Configurationa.yaml
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
http:
base_url: https://ha.domain.com
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Any help would be appreciated.
Do you have port 80-80 forwarded in your router?
Port 80, 443 and 8123 … however will do a can u see me port check
all ports definitely open and can be seen
What is the date of your certificate file
ls -l /path/to/file
And below is the contents of the log file wehne Lets Encrypt is run
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /data/letsencrypt/renewal/vintnet.com.conf
Cert not yet due for renewal
The following certs are not due for renewal yet:
/data/letsencrypt/live/domain.com/fullchain.pem expires on 2019-08-23 (skipped)
No renewals were attempted.
Posting your config properly may reveal something.
I ended up just buying a certificate and using that instead of Lets Encrypt.
At least i know that this issue dealt with for the next 2 years
