Hi all,
I’m trying to create a script which will go through a list of scene names (input_select). Every time the script is run it selects the next in the list and activates it. However only one of these scenes is applied in the real world. The scenes work (starting them generates the desired color for the light). Whatever I do only when the script hits oprit_voordeur_color_darkgoldenrod it is actually applied. Can someone please help me getting this to work?
scenes.yaml:
- id: '1624265630317'
entities:
light.oprit_voordeur:
effect_list:
- blink
- breathe
- okay
- channel_change
- finish_effect
- stop_effect
supported_color_modes:
- xy
color_mode: xy
brightness: 253
hs_color:
- 198.554
- 97.647
rgb_color:
- 6
- 178
- 255
xy_color:
- 0.145
- 0.215
color:
x: 0.145
y: 0.215
linkquality: 63
state: 'on'
update:
state: idle
update_available: false
friendly_name: Oprit Voordeur
supported_features: 61
- id: '1624265741778'
entities:
effect_list:
- blink
- breathe
- okay
- channel_change
- finish_effect
- stop_effect
- xy
color_mode: xy
brightness: 252
hs_color:
- 270.9
- 78.431
rgb_color:
- 158
- 55
- 255
xy_color:
- 0.252
- 0.106
color:
x: 0.252
y: 0.106
linkquality: 63
state: 'on'
update:
state: idle
- id: '1624265801613'
entities:
effect_list:
- blink
- breathe
- okay
- channel_change
- finish_effect
- stop_effect
- xy
color_mode: xy
brightness: 253
hs_color:
- 42.638
- 92.157
rgb_color:
- 255
- 187
- 20
xy_color:
- 0.53
- 0.44
color:
x: 0.53
y: 0.44
linkquality: 72
state: 'on'
update:
state: idle
scripts.yaml (notification is to verify the list is actually cycled)
alias: TEST Loop Through Scenes
sequence:
- service: input_select.select_next
entity_id: input_select.oprit_voordeur_color
- service: scene.turn_on
data_template:
entity_id: scene.{{ states ('input_select.oprit_voordeur_color') }}
- service: persistent_notification.create
data_template:
title: scene.{{ states ('input_select.oprit_voordeur_color') }}
message: scene.{{ states ('input_select.oprit_voordeur_color') }}
mode: single
