I am running OpenUV and have an automation to update it. My logs are filling up with
Mon Jan 28 2019 13:49:15 GMT-0800 (Pacific Standard Time)
Error doing job: Exception in callback <function async_track_utc_time_change..pattern_time_change_listener at 0x7fd48d4f4ae8>
File “uvloop/cbhandles.pyx”, line 64, in uvloop.loop.Handle._run
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/event.py”, line 368, in pattern_time_change_listener
calculate_next(now)
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/event.py”, line 353, in calculate_next
matching_hours)
File “/usr/local/lib/python3.6/site-packages/homeassistant/util/dt.py”, line 256, in find_next_time_expression_time
raise ValueError("Cannot find a next time: Time expression never "
ValueError: Cannot find a next time: Time expression never matches!
I am having the same issue but for the life of me cannot find the part that is wrong…
Error:
2019-01-31 07:37:47 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function async_track_utc_time_change..pattern_time_change_listener at 0x7f9bc8638b70>
File “/usr/src/app/homeassistant/helpers/event.py”, line 368, in pattern_time_change_listener
calculate_next(now)
File “/usr/src/app/homeassistant/helpers/event.py”, line 353, in calculate_next
matching_hours)
File “/usr/src/app/homeassistant/util/dt.py”, line 256, in find_next_time_expression_time
my automations.yaml:
- id: '1544978233171'
alias: Pollen_Text
- at: 07:00:00
platform: time
condition:
- above: '7'
condition: numeric_state
entity_id: sensor.allergy_index_today
- data:
message: Allergy Index is High
service: notify.gmail2
- id: '1544978233174'
alias: Alarm Away
hide_entity: true
- platform: state
entity_id: sensor.frontd_alarm_level
to: '255'
- platform: state
entity_id: sensor.garaged_alarm_level
to: '255'
- platform: state
entity_id: sensor.backd_alarm_level
to: '255'
- platform: state
entity_id: sensor.multisensor1_alarm_level
to: '255'
condition:
condition: state
entity_id: alarm_control_panel.ha_alarm
state: armed_away
service: alarm_control_panel.alarm_trigger
- id: '1544978233175'
alias: Alarm Home
hide_entity: true
- platform: state
to: '255'
- platform: state
to: '255'
- platform: state
to: '255'
condition:
condition: state
state: armed_home
- id: '1544978233176'
alias: Triggered Flash
hide_entity: true
platform: state
to: triggered
- service: script.turn_on
entity_id: script.light_flash
- service: notify.gmail
message: Home Alarm Triggered {{now().strftime("%Y%m%d-%H%M%S")}}
- id: '1544978233177'
alias: Disarmed Off
hide_entity: true
platform: state
to: disarmed
- service: script.turn_off
entity_id: script.light_loop
message: Home Alarm Reset {{now().strftime("%Y%m%d-%H%M%S")}}
- id: '1544978233179'
alias: Turn on Bedroom Motion Light
platform: state
entity_id: sensor.bedroom_motion_sensor
to: motion detected
service: homeassistant.turn_on
entity_id: light.sn2_led
alias: Turn off Bedroom Motion Light
platform: state
to: standby
service: homeassistant.turn_off
- id: '1544978233180'
alias: Wake Me Up
platform: template
value_template: '{{ states.sensor.time.state == states.sensor.alarm_time.state
condition:
condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.alarmweekday
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: state
state: 'off'
service: light.turn_on
entity_id:
- light.bathroom_lights_level
- light.lrlamp_level
- light.tablelamp_level
- light.dining_room_2
- light.ceiling_fan_light_2
- light.bedroom_light_2
brightness: 40
- id: '1548631482714'
alias: Garage Door -Reset
- hours: ''
minutes: ''
platform: time_pattern
seconds: '4'
condition:
- condition: state
entity_id: switch.garageswitch_switch
state: 'on'
- service: switch.turn_off
Hmm, I had rewrote it after my upgrade from 0.69 to 0.86 as it was throwing a format error (was time). It is suppose to work as if it sees the switch ‘on’, wait 4 seconds then turn off.
before the 0.86 update…
- id: '1544978233172'
alias: Garage Door Reset
hide_entity: true
- platform: time
seconds: /4
condition:
condition: state
state: 'on'
I figured that the internal one had done it correctly but I just the below version and the errors are gone… guess I just needed to see it in a message on home-assistant board, lol. I’ll have to test is later to make sure it still works.
The way you had it originally it would trigger every minute when the seconds = 04. The way you have it now it will trigger every 4 seconds (then check the condition).
It would be less load on the cpu if you did something like this;
- platform: state
to: 'on'
for:
seconds: 4
