[Solved] LOLIN Wemos SHT30 Shield not working: "Communication with SHT3xD failed!" esphome
Hello everybody.
This is fixed already but as I spent almost one hour trying to figure it out I thought I could share my experience.
So I bought some Wemos D1 modules and SHT30 shields. When I tried to put them to work using esphome I kept getting the message “Communication with SHT3xD failed!”
I tried everything, changing the way the SCL and SDA pins are named, specifying diferent frequencies, changing boards, reading the datasheet, etc.
Then I tried to use Arduino IDE and an example from Wemos to check the “health” of the D1 board and shield.
In arduino everything worked flawlessely.
I then reprogramed the D1 board with the esphome and suddendly everything started to work. I do not know what happened but it now works. :S
My code below:
# Define I2C bus
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
  #frequency: 100000
# Sensors
  - platform: sht3xd
    i2c_id: bus_a
    temperature:
      on_value:
        - switch.toggle: builtinled
        - delay: 50ms
    humidity:
      on_value:
        - delay: 50ms
    address: 0x45
    update_interval: 10s
  - platform: bh1750
    i2c_id: bus_a
    address: 0x23
    measurement_duration: 69
    update_interval: 60s
    on_value:
      - delay: 50ms
#Outputs
switch:
  - platform: gpio
    pin: D4
    inverted: true
    restore_mode: ALWAYS_OFF # Starts OFF
Thank you. :slight_smile:
You know the i2c address the shield uses?
And what does the logger say after start up (you have i2c scan set to true so if it finds a device it will even print the i2c address :bulb:)
Hello orange-assistant,
You can see the adresses in the code and the log find them. The adresses were discovered even when it was not posible to talk to the module, but as I said, after trying with arduino, everything started to work.
Thank you.
Maybe it was just a bad wiring/loose contact than.
See you around Fabio :wave:
