[Solved] Lutron Homeworks Lights Do Not Update
Hi all, apologies if this is the wrong place to post this…I’m new here…
Anyways, I’ve got an old Lutron Homeworks Series 8 system installed and I’ve managed to integrate it into Home Assistant using this integration: Lutron Homeworks - Home Assistant.
I’m using a Moxa NPort Serial to Ethernet adapter connected to the Homeworks processer.
When I first start up HA, everything works fine. Lights turn on and off and everything functions like normal. After a while (the time varies, sometimes it’s 10 seconds, sometimes it’s 10 hours) the Lutron lights stop responding in HA. The keypads and physical dimmers still work fine, but when a light is turned on either via HA or a physical switch, HA does not update that light so it remains “off” in Home Assistant. Other devices still work fine in HA. Only Lutron lights stop responding.
Sometimes HA can still control the light (ie dimming and turning on) but the light is stuck in the “Off” position on my dashboard & everywhere else in HA, so I can’t actually turn it off from Home Assistant. Other times, HA cannot control the light or see its on/off status.
I’m running Home Assistant 2021.11.0 on an Intel NUC as HomeAssistant OS. (ie, not through docker - the NUC boots into HA & has nothing else on it)
This also happened when I was using a RasPi 4.
Does anyone know how to fix this so the lights update reliably?
UPDATE: For anyone who might stumble across this later, I was able to fix the issue! On the Serial to Ethernet Adapter, the flow control needed to be set to DTR/DSR in order for the integration to work. After fixing that and restarting HA, everything works flawlessly!
@ghersh thanks for updating your post since it helped me with a similar issue. I’m curious have you been able to use the integration to get your keypads working? My dimmers work perfectly but I can’t figure out how to make the keypads work. I have added a keypad and I can see events firing in the Developer Console but I don’t know how to take that information and simulate a button press on the keypad.
Any suggestions?
I haven’t been able to get anything working with the keypads, unfortunately. I’ll keep you posted if I do…
Oh, glad I found this thread. Does anyone have any documentation or know how to wire up an RPi to the Lutron Homeworks (Series 4) multidrop serial device busses?
I have a system that has a number of SeeTouch wall buttons (with up/down dimmer buttons) and a bunch of WPMs in the walls. How do I interface the new Pi with the old Homeworks?
Hi @ghersh
Sorry for replying to such an old thread, but I’m having a similar problem, but I’m not sure it’s the same. I’ve tried every setting on the Moxa to get it to communicate both ways, but it continues to only update from HA->Lutron.
I have the Moxa set to TCP Server Mode with local port 4001 and command port 4001 with my serial port on DTR/DSR (per your above). My config YAML file has the following:
homeworks:
host: xxxx
port: 4001
Everything connects when HA boots and I can control from HA → Lutron, but I don’t get anything back from Lutron->HA. All the lights show as “off”.
Would you mind sharing any differences in your config? I so appreciate the help. HA has been awesome for me, but I would LOVE to be able to get Lutron to update both ways.
Thank you so much in advance!!
Is there a reason that the Homeworks integration only uses RS232 instead of the available ethernet jack on the processor? I don’t have an available serial to ethernet adapter and was hoping to connect directly to the processor through the RJ45 jack. I tried updating the configuration.yaml file and also tried creating a “custom integration” but neither seemed to work. I’m not sure if this thread is the proper place for this question, but any help would be appreciated.
I also have a large olderer Lutron Homeworks Series 8 system installed and I’ve managed to integrate it into Home Assistant using this integration: Lutron Homeworks - Home Assistant .
I’m using a Moxa NPort Serial to Ethernet adapter connected to the Homeworks processor. I am not seeing any of the keypads listed as entities. Lighting loads do show. Just curious if someone has ever been able to get the keypads to show. I can create a button but without the entity I am in the dark here. Have about 40 keypads to enter.
I’ve been spending no less than four hours a day for over a week to try to get two things, moxa, homeworks
with home assistant. I’m so stuck. I can’t activate a serial command. I can’t activate a mod bus command. If you have any sort of instructions, I would be your best friend forever. Please help. I have been searching extensively
Definitely late to the party….I’m redoing my Homework’s/HA integration since I’ve changed HA hardware this week. I’ll document everything here and update this thread with exact steps when I finish if you’d like!
Update as of 2025:
For anyone who may stumble upon this…here is my update!
  1. Remove any and all yaml config for Homeworks. The new integration is GUI based.
  2. The type of Serial Cable you order matters. I believe I’m using a full handshake/7 wire null modem cable like this: Amazon.com (Note, because I ordered the cable years ago, I can’t remember which I ended up using. I’m moderately confident this info is correct, but take it with a grain of salt.
  3. The RS232 Server also matters. I tested a few, but found the Moxa Nport to be the most reliable. Amazon.com: MOXA NPort 5110-1 Port Serial Device Server, 10/100 Ethernet, RS232, DB9 Male : Electronics
2a) The settings on the Nport must exactly match that of the Lutron Controller. Baud Rate, Data Bits, Stop Bits, Parity, Flow Control, FIFO must exactly match that of the Lutron Controller.
NOTE: In my research, the default baud rate of a Lutron controller is 9600…HOWEVER this was not the case for my controller, and I had to use the following:
  • Baud: 115200
  • Data Bits: 8
  • Stop Bits: 1
  • Parity: None
  • Flow Control: DTR/DSR
  • FIFO: Enable
  1. The wiring is relatively simple: Lutron Controller > RS232 Cable > Nport > Ethernet.
  2. Since I started in 2021, the Lutron integration has had several updates. (to those working on this integration, I genuinely cannot thank you enough!)
    You will need a way to find your Homeworks light addresses and Keypad addresses.
    In my case, I was able to reach out to an integrator who was able to provide me with a PDF that included this information. I believe there are ways to pull this from the Homeworks integration, however I did not test this.
Lights will have an address in the form of [##:##:##:##:##]
and Keypads will have the form [##:##:##].
  1. The updated Lutron integration has a GUI that allows you to configure and update lights and keypads. It is very slick! You can program individual buttons on the keypad(s) and import them into HA. I’ve also tested and it works with non-lights too. For example, my Lutron system had a set of drapes that can be controlled through HA. It also had a bathroom vent fan that I can control just by simulating a keypad button press.
The process of importing all of the lights, keypads, and buttons is a bit time consuming, but the integration has been ROCK SOLID for me since setting it up. I’m even able to use the HomeKit bridge to control my lights via Apple Home.
As a side note/word of warning…for those of you working with older Homeworks processers, apparently they’re susceptible to battery issues as they age. Definitely something to be aware of and put on your radar.
Hopefully this is helpful to anyone searching in the future!
