Give the lang delay in hue motion sensor response, I created a second machine containing home assistant in a venv under Ubuntu 18.04. I have the community support version in docker on that machine. I have added 4 motion sensors that communicate with my main HA via mqtt. These are all working well. I have a hue dimmer also installed via phoscon named living_room_switch. The firmware shows as up to date. I’ve added deconz logging to HA in the machine containing deconz. When I press buttons on the hue dimmer I don’t see any events. In the HA logs (Should they be there?). The automation shown below is not triggered (should it be?). I’m definitely not sure where to go from here.
- id: living_room_button_one
alias: living_room_button_one
- event_data:
event: 1001
event_type: deconz_event
platform: event
- event_data:
event: 1002
platform: event
- data:
payload: '1'
retain: 'true'
topic: conbee/sensor/living_room_switch/state
service: mqtt.publish
