Ok I promise I’m not trying to bomb out the forum today.
So problem #2 for me today. While researching how to track an unchanged state I found this example here
which I took and set it up for what I needed it to do as
import appdaemon.appapi as appapi
import homeassistant.util.dt as dt_util
import datetime
# Notify stale sensors.
# Each minute last update of sensor is checked to see if it is higher than the configured value
# Args:
# sensor = sensor to monitor
# minute = minutes threshold to notify
# notify = comma separated list of notifiers
class StaleSensor(appapi.AppDaemon):
def initialize(self):
time = datetime.time(0, 0, 0)
self.run_minutely(self.check_sensor, time)
def check_sensor(self, kwargs):
now = dt_util.now()
sensor_last_updated_str = self.get_state(self.args["sensorID"], "last_updated")
sensor_last_updated = dt_util.parse_datetime(sensor_last_updated_str)
minutes = int(self.args["minutes"])
stale_time = now - sensor_last_updated
if stale_time.seconds > minutes*60:
self.log("The power meter hasn't updated in a while so we're going to restart it")
self.turn_off(self.args["switchID"])
self.run_in(self.switch_on_function, 5)
def light_off(self,kwargs):
self.turn_on(self.args["switchID"])
I have an aeon lab energy meter that occasionally throughout the day just decides it no longer wants to report so the fix is I stuck a leviton zwave plug module on it and I turn that off and back on. In ST I was monitoring the value for it to remain the same over 4 mins. Problem is that I get a lot of false positives where the energy usage value has changed but the reading from 4 min ago vs now is actually the same. So the fix is turn it off for 5 seconds and then back on.
My hope is that with appdaemon I can do this a little more graceful and this code example looked like it would do the trick. But HA complains about this
I’m guessing that either HASSIO doesn’t know how to import that or its been deprecated with HASSIO and there is possibly another library that I can utilize instead to accomplish what this library was accomplishing. Thank you for your help with this and if there is a better api reference for a value unchanged and I just can’t find it in the docs please feel free to slap me around, as I am def not trying to waste ones time with simple things although I’m sure that others might have a need for monitoring a value that isn’t changing.
