I am getting desperate. I can not connect to home assistant via MQTT.fx software or my NodeMcu device… I have the hassio Mosquito addon installed, and in the options I have:
Big thanks to you guys! Changed it to py pi:s IP adress and it worked.
For some weird reason I had the assumption that the broker IP should be different than the pis ip, but now that I think about it, that does’t make any sense.
