For several frustrating weeks I have been trying to create a reliable Zigbee network.
I have around 200 Zigbee devices (most Philips Hue bulbs) on a single floor. 95% are main powered and 5 IKEA repeaters spread around the house. Nevertheless, commands are often not arriving.
Currently, all devices are connected to SkyConnect (on a well-shielded USB cable far away from all sources of interference, USB 2.0, in the center of the house, channel away from WiFi 2.4 channels). I have tried ZHA and Zigbee2MQTT - currently Z2M.
Other users with many devices reported that they have solved these problems by splitting the network between 2 or more coordinators. So this is my last attempt before I have to go back to my 4 Hue Bridges.
But Iām having trouble getting the different Zigbee2MQTT instances to work.
My plan is to have 4 LAN coordinators (CC2652) distributed in the house with Zigbee2MQTT and one LAN coordinator (EFR32) with ZHA for the outdoor devices.
In the first step, I installed the add-on a second time (with / at the end of the URL). So in the end I could install two Z2M Standard Add-ons and two Z2M Edge Add-ons.
Then I initially configured first the EFR32 coordinator:
data_path: /config/zigbee2mqtt_5
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8490,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt: {}
serial:
port: tcp://192.168.2.195:6638
adapter: ezsp
It starts up without any problem. I then changed the Zigbee channel to 15 in the Z2M UI. 22 devices registered without any problems. All devices from both add-ons appear in the MQTT integration and can be controlled in HA - so far everything was fine.
Now the further expansion should take place and I have set up the first CC2652 LAN Coordinator in the first Z2M Edge add-on:
data_path: /config/zigbee2mqtt_3
socat:
enabled: false
slave: tcp-listen:8493,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt_3
server: mqtt://localhost:1883
serial:
port: tcp://192.168.2.193:6638
It has not started in the Info tab, and the log does not show more than the first 3 lines āStarting ā¦ā. The UI is also not available.
The main problem is that all 200 devices of the first add-on, to which all devices in the house are currently connected, have disappeared from the MQTT integration. They are still visible in the Z2M UI and can still be operated via it. I think I remember the Z2M configuration.yaml no longer has any devices.
Since we can no longer sit here in the dark, I had to import a full HA backup (takes 2 hours).
Unfortunately, I donāt understand Z2M and MQTT broker deeply enough. I suspect that this is where the various add-ons interfere. But I have changed the data_path.
Any help is very welcome. I donāt want to give up the self host approach and use the Hue Bridges again.
