Hey,
I set up a docker Mosquitto, Zigbee2Mqtt & HomeAssistant.
On HA, I am using the integration MQTT (nothing in my configuration.yaml)
For Zigbee2mqtt:
I wasnt sure if homeassistant integration was for HASS docker addons or if you are just using homeassistant at all. Since I am running my own docker mqtt I tried both and it didnt solve the problem.
# Home Assistant integration (MQTT discovery)
homeassistant: false
# allow new devices to join
permit_join: true
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: zigbee2mqtt
# MQTT server URL
server: 'mqtt://192.168.xxx.xxx'
# MQTT server authentication, uncomment if required:
user: xx
password: xx
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: /dev/ttyACM1
Zigbee2mqtt Log
info 2020-04-17 15:42:14: Logging to console and directory: '/app/data/log/2020-04-17.15-42-14' filename: log.txt
info 2020-04-17 15:42:15: Starting zigbee2mqtt version 1.12.2 (commit #7d27a54)
info 2020-04-17 15:42:15: Starting zigbee-herdsman...
info 2020-04-17 15:42:16: zigbee-herdsman started
info 2020-04-17 15:42:16: Coordinator firmware version: '{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20180507}}'
info 2020-04-17 15:42:16: Currently 3 devices are joined:
info 2020-04-17 15:42:16: Stat 2 (0x00158d00023208ae): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
info 2020-04-17 15:42:16: Stat 3 (0x00158d0002437c56): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
info 2020-04-17 15:42:16: Stat 1 (0x00158d0002437b49): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
warn 2020-04-17 15:42:16: `permit_join` set to `true` in configuration.yaml.
warn 2020-04-17 15:42:16: Allowing new devices to join.
warn 2020-04-17 15:42:16: Set `permit_join` to `false` once you joined all devices.
info 2020-04-17 15:42:16: Zigbee: allowing new devices to join.
info 2020-04-17 15:42:16: Connecting to MQTT server at mqtt://192.168.xxx.xxx
info 2020-04-17 15:42:17: Connected to MQTT server
info 2020-04-17 15:42:17: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
info 2020-04-17 15:42:17: MQTT publish: topic 'zigbee2mqtt/Stat 2', payload '{"temperature":22.15,"linkquality":44,"humidity":55.89,"pressure":1012.2,"battery":100,"voltage":3015}'
info 2020-04-17 15:42:17: MQTT publish: topic 'zigbee2mqtt/Stat 3', payload '{"temperature":22.48,"linkquality":36,"humidity":50.2,"pressure":1011.4,"battery":41,"voltage":2895}'
info 2020-04-17 15:42:17: MQTT publish: topic 'zigbee2mqtt/Stat 1', payload '{"battery":100,"voltage":3015,"temperature":22.49,"humidity":57.38,"pressure":1012.2,"linkquality":23}'
info 2020-04-17 15:42:17: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.12.2","commit":"7d27a54","coordinator":{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20180507}},"log_level":"info","permit_join":true}'
info 2020-04-17 15:49:34: MQTT publish: topic 'zigbee2mqtt/Stat 3', payload '{"temperature":22.45,"linkquality":2,"humidity":50.34,"pressure":1011.6,"battery":41,"voltage":2895}'
info 2020-04-17 15:49:34: MQTT publish: topic 'zigbee2mqtt/Stat 3', payload '{"temperature":22.45,"linkquality":7,"humidity":50.34,"pressure":1011.6,"battery":41,"voltage":2895}'
And Mqtt log:
|2020-04-17 22:42:39|stdout|1587163359: New client connected from 192.168.xxx.xxx as auto-F64B2979-88C1-C473-9945-3E9526CF172D (p2, c1, k60, u'xxxx').|
|2020-04-17 22:42:39|stdout|1587163359: New connection from 192.168.xxx.xxx on port 1883.|
Finally, in homeassistant it shows mqtt as “No Devices Found”
