I have seen problems since a few days with my Ikea Tradfri integration.
No automations with Tradfri are executed.
I looked in the core logs and I get plenty of
2021-03-28 20:56:10 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: tradfri
I looked in the Ikea app and it says that a new gateway firmware (1.13.25) was installed March 25th.
Anyone that have seen same problem?
I’m running core-2021.3.4.
After rebooting the host I got this in the core log:
2021-03-28 21:07:01 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry 192.168.1.71 for tradfri
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 248, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File “/usr/src/homeassistant/homeassistant/components/tradfri/init.py”, line 126, in async_setup_entry
devices_commands = await api(gateway.get_devices())
File “/usr/local/lib/python3.8/site-packages/pytradfri/api/aiocoap_api.py”, line 168, in request
result = await self._execute(api_commands)
File “/usr/local/lib/python3.8/site-packages/pytradfri/api/aiocoap_api.py”, line 152, in _execute
_, res = await self._get_response(msg)
File “/usr/local/lib/python3.8/site-packages/pytradfri/api/aiocoap_api.py”, line 96, in _get_response
r = await pr.response
File “/usr/local/lib/python3.8/site-packages/aiocoap/protocol.py”, line 731, in _run_outer
await cls._run(app_request, response, weak_observation, protocol, log)
File “/usr/local/lib/python3.8/site-packages/aiocoap/protocol.py”, line 783, in _run
blockresponse = await blockrequest.response
File “/usr/local/lib/python3.8/site-packages/aiocoap/protocol.py”, line 313, in send
request_interface.request(plumbing_request)
File “/usr/local/lib/python3.8/site-packages/aiocoap/tokenmanager.py”, line 243, in request
self.outgoing_requests[key] = request
TypeError: ‘NoneType’ object does not support item assignment
