[solved] Name from Shelly Plug S Gen3 not used in Home Assistent
I started today using Home Assistent and found an issue with Shelly Plug S Gen3.
In Shelly Cloud they are named with some readyble names.
After adding them to Home Assistent they were shown with “shelly[some iD]”, so I renamed them. But on Dashboard still the first name is used:
Ist this a (known) bug? How can I solve it?
Br, Michael
Did you import the card from the device page?
Then the old names were also imported.
For the title you need to edit the card and change the title value.
For the entities you need to edit the card, go to the entity you want to rename, click the pencil and then edit the name.
I see, thx a lot!
