A couple of weeks ago I programmed a couple of sonoff T1 2 channels with tasmota as per the tasmota wiki - no problems
Just got 7 more (Banggood via china - same supplier) T1 2C’s and cannot get them into flash mode what ever I do !!
I first checked that all worked using sonoff ewelink and even updated one to see if they can be reprogrammed 2.7.1V - fine.
Have tried the wiki - power up/press touch button 1/press reset button/release touch button 1 - wifi led keeps flashing - original ewelink program still running
Tried shorting R19 to ground - same as touch 1 - no go
Tried powering up with various buttons pressed/shorts - no go
Always get WIFI led on or flashing.
Tried using termite to see it the sonoff goes into flash mode but get junk - tried 9600/74880/115200
Hex view below
78 00 78 00 c3 78 1e 7f 3c 0f 3c fe 80 78 1e 87 x.x.Ãx.<.<þ€x.‡
00 78 e0 80 78 00 03 e0 78 1e ff 80 f8 f8 78 fe .xà€x…àx.ÿ€øøxþ
78 fe 78 fe f8 00 xþxþø.
Same junk if I use Putty - maybe its Chinese
Tried using 2 different USB TTL adapters - they worked for my other sonoffs (Basic/Dual/Power/Orig T1)
Measured the voltage rails 3.1-3.2V so even provided another 3.3V supply (Breadboard PSU - common OV)
New board layout/version numbers match the 2 I got before
Any thoughts ?
Leigh
