I am running latest docker version of hassio/ha etc on a arm 64 board
arch
aarch64
dev
false
docker
true
hassio
true
os_name
Linux
python_version
3.7.4
timezone
America/Vancouver
version
0.96.0b2
virtualenv
false
I suppose something has changed because the configuration check button at /config/core is missing/gone.
So I loaded via hassio the addon core configurator ( now version 2.2). It takes forever to parse and evaluate and then the log does not indicate anything wrong although clearly I have an automation that has an issue as indicated by a notification.
Can someone illuminate how to get my configuration checked with this version. I’m running blind with no check/log of my configuration and thus can’t really keep developing.
for example this automation is not showing up in the states so I assume it has an issue
Turns out that particular issue I needed to use plattform: time_pattern. That’s great I figured it out (guessed) but the configuration check either “built in” or via the add on is no help. :-(.
So simple!! Even though my user was the only andadmin user apparently this setting was turned off when this new version was installed.
Now @VDRainer just a little other suggestion. Any way to put that button at the top of that page? The location setting dialog appears before it so I must scroll down every time just to press this button.
Better yet is there a way to access or place this in a more convenient location for development?
Don’t ask me, i’m no developer.
But there are multiple requests here and on github about the config check and restart buttons.
I’m sure there’s someting in progress.
In the past I was in the same situation where advanced mode was turned off after an update.
Now (0.97 and also 0.97.1) with the advanced mode on it still does not show the config check button and restart buttons at the bottom of Configuration/General. I toggled a few times advanced mode off and on, but no change. Might there something be missing in configuration.yaml?
EDIT:
Found it! It was moved to separate section; Server control, right under General at Configuration page…
I was having this same issue with the update to 2023.7.1, some of my addons were turned off and when trying to turn them on I got these notifications (all simelar):
File explorer (Didnt entirely copy it after fixing it):
amd64-addon-configurator:5.6.0 does not exist for addon_core_configurator
AppDeamon:
Image ghcr.io/hassio-addons/appdaemon/amd64:0.13.1 does not exist for addon_a0d7b954_appdaemon
DuckDNS:
Image homeassistant/amd64-addon-duckdns:1.15.0 does not exist for addon_core_duckdns
Silicon labs multiprotocol:
Image homeassistant/amd64-addon-silabs-multiprotocol:2.2.0 does not exist for addon_core_silabs_multiprotocol
Home assistant google backup (I know this isnt an official Home assistant addon but it produced the same kind of error):
Image sabeechen/hassio-google-drive-backup-amd64:0.111.1 does not exist for addon_cebe7a76_hassio_google_drive_backup
The only option was OK with all of these addons and they were all up and running just fine before the update. The only thing that worked for me was just copying the yaml configuration and then reinstalling the addons. Not sure what happend,
For anyone wondering what the logs are, here is what I found (sorry I never really had a close look at the Home assistant logging page and how to use it so if I forget smth just tell me):
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:130
Integration: Home Assistant Supervisor ([documentation](https://www.home-assistant.io/integrations/hassio), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+hassio%22))
First occurred: 12:09:58 AM (9 occurrences)
Last logged: 12:21:10 AM
* Failed to to call /addons/core_configurator/start - Image homeassistant/amd64-addon-configurator:5.6.0 does not exist for addon_core_configurator
* Failed to to call /addons/a0d7b954_appdaemon/start - Image ghcr.io/hassio-addons/appdaemon/amd64:0.13.1 does not exist for addon_a0d7b954_appdaemon
* Failed to to call /addons/core_silabs_multiprotocol/start - Image homeassistant/amd64-addon-silabs-multiprotocol:2.2.0 does not exist for addon_core_silabs_multiprotocol
* Failed to to call /addons/cebe7a76_hassio_google_drive_backup/start - Image sabeechen/hassio-google-drive-backup-amd64:0.111.1 does not exist for addon_cebe7a76_hassio_google_drive_backup
For anyone only reading the last sentence, copy/backup yaml/addon and reinstalling the addon(s) worked for me.
Hope this helped someone and I hope you have a wonderful day!
