Everything was running smoothly when I decided to upgrade ^^
I was in 0.43 and now 0.60.1
I must have done something wrong because I can’t have zwave to work.
OZWCP seems to work fine, I get all my zwave devices in it !
But when I start HA I get
2018-01-06 23:38:31 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/data/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 193, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/data/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/__init__.py", line 257, in setup
from openzwave.option import ZWaveOption
File "/data/homeassistant/lib/python3.5/site-packages/openzwave/option.py", line 29, in <module>
import libopenzwave
ImportError: /data/homeassistant/lib/python3.5/site-packages/libopenzwave.cpython-35m-arm-linux-gnueabihf.so: undefined symbol: _ZN9OpenZWave7Manager16GetNodeProductIdB5cxx11Ejh
Nothing in OZW_Log.txt since I have recompiled python-openzwave…weird…
If someone have an idea to help me resolve this error…
Can someone propose a clean way to do it ?
I tried several ways and now I have another error message !
2018-01-07 10:37:47 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
future.result()
File "/data/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/__init__.py", line 280, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File "/data/homeassistant/lib/python3.5/site-packages/openzwave/option.py", line 83, in __init__
self._user_path = user_path
AttributeError: attribute '_user_path' of 'libopenzwave.PyOptions' objects is not writable
A permissions problem ? but I can’t find where…
Thx
I deleted the whole directory and reinstalled homeassistant.
I removed the config_path line in the configuration.yaml and the zwave network is back…!
Is openzwave installed by homeassistant now ?
