I might have the simplest and most stupid question of all, but I do not find what I do wrong.
I am trying to configure the deConz server within Node Red, as described in this video. However, whatever I try and find in the internet, I get the message:
It does not matter that IP i put in. Going to 192.168.178.100:40850 brings me to the Deconz login page. So it should work…
Please, double check your IP address and port, for example, port specified above and in the print screen is not the same one. And second thing, are you sure about your websocket port?
I left the API key empty and authorized third party apps indeed, and I tried with manual API input. For API I put the section with red. Fot this string from the logs of Deconz in Home Assistant.
Thanks for the tips. I couldn’t make it work in any way. Even in manual mode I’ve got “No response from server” when tried to get the API password. Then I tried your tips 1 and 2, and after restart I just saw it in the deConz log file as "172.30.XX.XX - - [27/Apr/2020:18:59:39 -0500] “GET /api/BF67XXXX62/config?_=15880XXXX8293 HTTP/1.1” 200 2180 " where BF67XXXX62 is the API password.
