Hi2UAll,
I have managed to write files using the Node-RED add-on. The location to write files to is /homeassistant/www/ as mentioned by @frenck.
Is there a way to write the file to a location which is not publicable accessible?
Thanks in advance.
Hi2UAll,
Thanks in advance.
Thanks, I will try that later on.
@Mikefila Do you mean Node-RED files can be accessable on these lcations (/media) ?
Node-RED files cannot add lines to the file stored in /media, to bad.
BTW I added it to my config as mentioned in your post.
It is working but not when using sub-directories. @Mikefila Thank you!
What files are you trying to access? I use /media
to store photos, text files, etc. I can write or read anything stored in that location from node red.
lol I see the update
