I recently decided to upgrade from a Pi3 b to a Pi 4 b 8gb for my home assistant installation. The following was my process in doing so:
Make a snapshot of the Pi3 installation.
Use Balena etcher to put image of hassos specifically for Pi 4 8gb 64 bit onto brand new sd
Insert new sd into Pi4 and allowed to install
Made Pi4 restore from snapshot made in step 1.
Unplugged Pi3
Changed internal ip address of Pi4 to the same of the Pi3
Everything works properly except I am unable to access home assistant from the DuckDNS I had set up previously with the Pi3. I am unable to access home assistant outside of my home and the mobile app is also not able to connect. What did I miss that needs adjusted to account for upgrade to allow that?
Thanks for the suggestion! I just generated a new token through duckdns and copied that into the configuration for the addon, then restarted home assistant after saving. I am still unable to access it through the duckdns link.
[SOLVED]
For anyone who has similar issues, I discovered the cause.
Within my router I had set up some port management rules to forward 443 > 8123 TCP for duckdns to get to my pi home assistant. Obviously a new device is going to have a new mac address, so even though the rule was still in place, it was the wrong mac address for the new pi. After I deleted the old port forwarding and recreated, everything is working properly.
