Hi, trying to use a global ‘variable’ to set a trigger’s limits. Would be nice to have one UI control to set that variable.
My best try for the trigger is:
alias: 3 lent HVAC force max temp
description: ""
- platform: numeric_state
entity_id: climate.c630bcb0
for:
hours: 0
minutes: 0
seconds: 10
attribute: temperature
above: var.hvac_max_temperature
condition: []
- service: climate.set_temperature
temperature: var.hvac_max_temperature)
mode: single
I’m using GitHub - snarky-snark/home-assistant-variables: A custom Home Assistant component for declaring and setting generic variable entities dynamically. for variables.
Declaring variables:
var:
hvac_max_temperature:
initial_value: 30.0
friendly_name: 'HVAC max temperature'
unit_of_measurement: C
hvac_min_temperature:
initial_value: 18.0
friendly_name: 'HVAC min temperature'
On save HASS complains: Message malformed: expected float for dictionary value @ data['above']
Also tried above: {{ float(var.hvac_max_temperature) }}
but that does not work either.
What am I missing? Is there any better solution for this?
