I am experimenting w/ Home Assistant and Zigbee. I currently have 2 Zigbee devices. A temperature sensor (Sonoff) and a socket (Nous A1Z which is detected by zigbee2mqtt as TS011F_plug_1.
I observe (in the frontend of zigbee2mqtt and after several pairing attempts) that the socket seems to be correctly detected; in read + “write” (i.e. send commands) mode.
However, in Home Assistant, only some features are available. E.g.
- I can see/control the “on/off” state.
- E.g. Voltage, Current appears as field, but doesn’t have a value
I’m wondering if I need to do some kind of manual mapping to “help” HA better understand the capabilities of the socket? Or to force somehow the re-descovery of the socket? In zigbee2mqtt, initially, it was saying “interviewing failed”, but the device seemed to work, at least partially. I also observed that the current was in A instead of mA. After the last re-pairing attempt, the interviewing was OK, and the issue w/ A/mA was solved.
Maybe HA saw for the first time the socket when it was “corrupt”, and that’s why it works like this now?
Thanks a lot in advance.
Cristian.
