[SOLVED] patternWarning for Templates in configuration.yaml
Since I have updated to the new way of doing templates, I am getting a “patternWarning” on my “template:” like. This is what I have:
# Templates
template: !include_dir_merge_list templates/
I have a directory called “templates” in my top-level directory (same level the “configuration.yaml” file is at). Not sure if there is something else I need to do? Home Assistant has been restart multiple times since (for various reasons)
Despite this “patternWarning”, though, what I have in my “templates” directory does seem to be getting picked up by HA, so it does seem to be working; it would just be nice to get rind of the “patternWarning”
Where are you seeing this patternWarning, and what exactly does it say?
Ignore those warnings in Studio Code. The Home Assistant helper is outdated.
The warning is is Studio Code Server (which I realize I should have specified),
Edwin_D has responded indicating to ignore those errors in Studio Code Server, so I will :slight_smile:
Shouldn’t the correct answer be that Home Assistant helper needs to be updated and then we can try and get this to the correct people?
