I’m completely new to HA and been struggeling a couple of days now with getting the token for my AC, finally got it and try to install climate_ip.
This integration.
Downloaded the code and copied to config\custom_components\climate_ip.
In config.yaml I have this code:
platform: climate_ip
config_file: ‘samsung_2878.yaml’
ip_address: ‘xx’
token: ‘xx’
cert: ‘ac14k_m.pem’
mac: ‘xx’
But only get error in HA: Platform error tts.climate_ip - Integration ‘climate_ip’ not found.
edit:::new error Platform error climate.climate_ip - Integration ‘climate_ip’ not found.
Don’t understand what I am doing wrong here?
edit: installed an old version, got it working with using the newest one found here: GitHub - atxbyea/samsungrac: Home Assistant Climate Device for controlling (not only) Samsung AC
atxbyea has taken over the maintenance.
In case somebody stumble upon this thread in google
tom_l
December 31, 2021, 1:31am
2
There seems to be a major omission from the climate_ip instructions .
Instead of putting that config drectly in configuration.yaml you should put it under climate:
in configuration.yaml.
e.g. configuration.yaml
climate:
- platform: climate_ip
config_file: 'samsung_2878.yaml'
ip_address: ...etc
After adding this, save the file and restart home assistant.
Hmm, tried that now but still same error message…
tom_l
December 31, 2021, 11:51am
4
Well if it is the same error you have not done what I said. The error says you have incorrectly placed it under text to speach (TTS):
Show your configuration.yaml where you have included this. Including the parts above and below it.
Took a screenshot of my config now.
I have read that yaml files are somewhat strict programming language, so may be something I cant see here
Tiny update to the original thread: error: Platform error climate.climate_ip - Integration ‘climate_ip’ not found.
tom_l
December 31, 2021, 12:53pm
7
Right. So a completely different error.
You need to check that you have actually done this correctly and restarted:
Yeah, I’ve been trying different things while having this thread and a fb thread going on at the same time, so forgot to update the new error. Tried to edit and change folders, but to no good.
I shall delete all the files and start over again and see if that solves the problem. Just have to take a break before I throw my computer in the wall, haha
tom_l
December 31, 2021, 1:01pm
9
When downloading the files from github make sure you select “download zip”.
Got it working, updated topic and original thread with solution.
Installed the old version, updated to the new one found here : GitHub - atxbyea/samsungrac: Home Assistant Climate Device for controlling (not only) Samsung AC
