Hi everybody,
I am using SPZB0001
zigbee thermostats on my radiators and Xiaomi Door Sensors
(also zigbee) for my doors and windows.
As temperatures changed rather quick from too hot to too cold (located in Northern Germany), I had to quickly set this up in Home Assistant (switched to HA a few months ago and used a different solution before, so I had to start fresh with my automations for this).
Below is one example from my heating package, which includes a similar code for each thermostat, door, and window, but to make it easier to read I stripped it down to this one specific radiator.
# input slider so that I can set each radiator manually
input_number:
slider01:
initial: 17.5
<<: &heizung_template
min: 5
max: 25
step: 1
icon: mdi:radiator
unit_of_measurement: "°C"
# automations for
# 1. setting temperature
# 2. automatically turning off when window open
# 3. because of time_pattern (see below) automatically set temperature to previous value when window has been closed
automation:
- id: 'heizung_az_set'
alias: "[Heizung] AZ Set"
- platform: time_pattern # pretty sure there is a MUCH better way to do this; previously I had used "state", which worked, but it'd ONLY set temperature after I changed the slider; nothing would happen after a restart of Home Assistant, so I switched to time_pattern
seconds: "/10"
condition:
- condition: state
entity_id: binary_sensor.window_az_contact
state: "off"
- service: mqtt.publish
data_template:
topic: "zigbee2mqtt/Heizung_Arbeitszimmer/set"
payload: '{"current_heating_setpoint": {{ states.input_number.slider01.state | float }}}'
qos: 2
retain: false
- id: 'heizung_az_autooff'
alias: "[Heizung] AZ Auto Off"
- platform: state
entity_id: binary_sensor.fenster_az_contact
to: "on"
data_template: # using template so that I could change the (currently hardcoded) payload value of 5 to something variable
payload: '{"current_heating_setpoint": 5}'
qos: 2
retain: false
This works! I change the temperature via Home Assistant on my smartphone and it will almost instantly (max. 9 seconds delay due to time_pattern of 10 seconds) set the thermostat accordingly. So far, so good.
However, I have some ideas on how to improve this; are those good, or should I stick with my current solution:
- have one single automation for both
=> I am sure this will be possible somehow; I haven’t used jinja2 for templates much, but I thought it might be an option to have a single automation that will check whether or not the window is open, and, if so, return the “low” temperature value (currently hard coded to 5), and if not set and/or restore the previously set value. I just don’t know how to do this - use anchors
=> as you can see at the top withinput_number:
, I am using anchors for some keys/values so that I don’t have to type them over and over again; how would I do this for the entire automation below?
I would have to set anchors for
- automation:
- id
- alias
- condition:
- entity_id
- action:
- topic
- payload
If this is doable, I’d just need help with how to write the anchors part… because I don’t know how to use them in this more complex syntax (compared to what I did above, where every key/value for the anchor would be right below each other, without any indents etc. - hope I explained this somewhat understandably, I am not a native English speaker, so sorry if this sounds kinda weird).
Thank you for your ideas
