I did see those pages you are linking to (and many others)
It’s just that my first block of code doesn’t seem to correct and I have no clue what it has to be.
At first, I had no clue how to use it…
This ESPHome stuff & programming is new to me + English is not my native language which makes it’s harder to really understand that info.
Just gave it a try, somehow ‘guessed’ what had to be added and succeeded!
I didn’t know you were that new to ESP-Home, if I had known then I would have started up the computer to give you a more proper answer.
But great that you got it working
You helped me to make it work: that’s the most important.
Of course when you (I in this case) don’t know how to use the info that is available, it’s a little frustrating and it’s not a big deal to go through this, keep calm, and persist.
What is very typical: when it works, I often have this ‘that wasn’t so hard, right’…
