Hi everyone, I have opened an issue on github for the letsencrypt addon, not being able to renew a certificate:
Possible dns issue with let’s encrypt addon. acme-v01.api.letsencrypt.org is reachable from the host machine, but it seems it isn’t from the docker container. Hass.io and other addons don’t have this issue.
Host OS: Ubuntu Server 18.04LTS
Port 80 is always redirected to host port 80.
The cert was generated using this addon months ago.
Here is the log:
starting version 3.2.4
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Cert is due for renewal, auto-renewing…
Plugins selected: Authenticator standalone, Installer None
Attempting to renew cert (mydomain) from /data/letsencrypt/renewal/mydomain.conf produced an unexpected error: HTTPSConnectionPool(host=‘acme-v01.api.letsencrypt.org’, port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7fb848c97490>: Failed to establish a new connection: [Errno -3] Try again’,)). Skipping.
All renewal attempts failed. The following certs could not be renewed:
/data/letsencrypt/live/mydomain/fullchain.pem (failure)
1 renew failure(s), 0 parse failure(s)
Is there a easy way to add the option --dns 1.1.1.1 (or any other dns server) to the command line of this addon?
I’m afraid that this addon does not run for enough time to be able to log in into the image for futher investigation. My issue was motivated because I couldn’t renew a certificate, and after reporting the issue in Github, the creator of the addon gave the solution.
Can’t tell with the information you are giving.
Let’s encrypt is an addon to hassio. When you enable the certificate you’ll have to change your configuration.
Take a look at the logs you have avaliable. If the docker daemon doesn’t start it must be writing a log somewhere. Check your distro docker docs.
If your think it’s caused by another component or installation issue, better open a new topic
