[SOLVED]Problem with logical check in automation with trigger.to_state.state
I am trying to set up a notification everytime a door opens or closes.
The action of the automation looks like this:
      service: notify.up_lr_lg_tv
        message: "{{ trigger.from_state.attributes.friendly_name }} is now {{trigger.to_state.state}}"
Which works great, and outputs “Main door sensor is on” or “off” depending to the state.
Next, I am trying to change the on/off to Open/Closed following the documentation like this:
        message: "{{ trigger.from_state.attributes.friendly_name }} is now {% if is_state('trigger.to_state.state', 'on') %}Open{% else %}Closed{% endif %}!"
But this if, never checks as true. I always get XXX is now Closed, no matter if i open or close the door.
Any ideas?
I see 123 is replying. I want see if my suggestion:
        message: "{{ trigger.from_state.attributes.friendly_name }} is now {{ 'Open' if trigger.to_state.state == 'on' else 'Closed' }}."
Is correct. I have trouble with one line if/else templates.
Just add some quotes to the strings and I believe the reference to friendly_name can be shortened.
        message: "{{ trigger.from_state.name }} is now {{ 'Open' if is_state(trigger.to_state.state, 'on') else 'Closed' }}!"
Without the quotes it will consider Open and Closed to be the names of variables.
That looks fine Tom :slight_smile:
I snuck that edit in before your reply :slight_smile:
Also worth mentioning that trigger.from_state.name will fall back to an entity_id if no friendly name exists.
I’ve always liked that ‘fail-safe’ behavior because it works exactly the same way in Premise; when I first encountered it (many years ago) it struck me as being a simple but thoughtful touch.
Yeah it’s a definite improvement to the template.
I believe the format in the OP would have worked but there is a misunderstanding…I think…
You are using the “is_state” method but the trigger doesn’t use that (not sure exactly the terminology but I think that the trigger isn’t a “state object” so you can’t use the is_state() method on it).
trigger.to_state.state returns a string.
try this as a test to see if it works (I think it should):
message: "{{ trigger.from_state.attributes.friendly_name }} is now {% if trigger.to_state.state == 'on') %}Open{% else %}Closed{% endif %}!"
@123’s is a bit more compact but you were on the right track except for that tweak.
In fact it was easier than that, OP just needed to remove the single quotes from around trigger.to_state.state in the template as trigger is a variable.
That said, it is messy so I’m glad they asked and @123 cleaned it up.
so just to clarify you are saying this would work:
{% if is_state(trigger.to_state.state, 'on') %}Open{% else %}Closed{% endif %}
Yes. That is the ‘extended’ version of the second half of Taras’ compacted template.
Hmm…interesting.
I didn’t know you could use is_state() with variables as the tested object.
I’m pretty certain, and Taras had used the same convention so I’m in good company - but I’ll happily stand corrected :wink:
Yeah, now that I think about it a bit more I guess that the trigger is a state object since it actually does contain the “state” and all of the other data contained inside.
I just never picked up on that being considered a variable that could be used (without the quotes) in the state() or its variations.
Hey everyone,
Thank you for all the answers, glad I picked your mind and created some constructing conversation :slight_smile:
I wish i could try out all the options and tell you what’s up but right now it seems the whole notify.lg_tv thingy service is down. It doesnt work at all.
So ill troubleshoot this first and come back with results.
I figured it out, i specified a notifier group with the same name as the entity in it and it messed the whole thing up.
Anyways, back to the subject.
I am afraid none of them work.
and
"{{ trigger.from_state.attributes.friendly_name }} is now  {% if is_state(trigger.to_state.state, 'on') %}Open{% else %}Closed{% endif %}!"
Both give me Closed in both the situations where i open and close the door (binary sensor on and off)
Have you tried my version from my first post above:
but Taras’ version should work I think if nothing else does.
Gimme a sec, trying them now.
Does not work at all, no notification appears.
@123 is giving closed in both states
@tom_l’s worked:
We have a winner! :smiley: :partying_face:
Try this one too:
