I have an old eq3 system, connected via CUN device (reflashed cube) to Homegear -> internal setup and configuration working fine. E.g. heating off when window open etc.
No I connect HA to homegear -> working fine, all states properly shown.
Issue:
I have a wallthermostat, which shoudl control several radiators in the room. It does work when using the hardware thermostat, but not using HA. This is known to the max! components. I created the following automations in HA, whereby I created sensors to reflect the temperature/hvac_mode/presetmode attribute as I didnt want to have the automations run on any detected temperatur change or similar. The sensors are working fine and are showing the correct modes - e.g. triggers are working
- alias: "Wandthermostat WZ - Temperaturkontrolle"
- platform: state
entity_id: sensor.heating_wz_wallthermostat_temperature
- service: climate.set_temperature
data_template:
entity_id:
- climate.oeq0940198
- climate.oeq0946337
temperature: "{{ state_attr('climate.oeq0868432', 'temperature') }}"
- alias: "Wandthermostat WZ - Modekontrolle"
- platform: state
entity_id: sensor.heating_wz_wallthermostat_mode
- service: climate.set_hvac_mode
data_template:
entity_id:
hvac_mode: "{{ state_attr('climate.oeq0868432', 'hvac_mode') }}"
- alias: "Wandthermostat WZ - Boostkontrolle"
- platform: state
entity_id: sensor.heating_wz_wallthermostat_presetmode
- service: climate.set_preset_mode
data_template:
entity_id:
hvac_mode: "{{ state_attr('climate.oeq0868432', 'preset_mode') }}"
BUT. The issues I noticed and I need help with:
Can not switch to “heat” from “off” (only to “auto”)
When turning climate wall thermostat to “off” in HA, all radiators are going to “off”, but I cannot get them back into “heat” (manual) mode. I can only reactivate them using the “auto” (Automatic) mode.
-> Is this an issue in HA? or can somebody confirm that the Max! device firmware has that issue? Or homegear? I can confirm the issue without automations in the UI using a climate component. The issue is valid for the thermostats and wall thermostat.
Any hint what to look for in the logs would also be helpful. -
Boost mode cannot be activated
When I send the presetmode to be “boost”, the devices turn “off”. So does somebody know how I can activate the “boost” mode? I use to set the preset mode to “boost” as shown in the entity attributes.
Here are the entity attributes as shown by HA:
Of course this can also be a homegear issue, I simply havent found an answer yet.
Best regards and thanks in advance
For completeness, the sensor configuration used (file is integrated via “include”, sensors are working):
platform: template
sensors:
heating_wz_wallthermostat_mode:
entity_id:
- climate.oeq0868432
value_template: >-
{{ state_attr("climate.oeq0868432", "mode") }}
heating_wz_wallthermostat_temperature:
entity_id:
value_template: >-
{{ state_attr("climate.oeq0868432", "temperature") }}
heating_wz_wallthermostat_presetmode:
entity_id:
value_template: >-
{{ state_attr("climate.oeq0868432", "preset_mode") }}
