Hello forum,
I’m rendering my retina to nil on searching a solution which will give a pulse to a GPIO for less than a second.
I’ve visited almost hundred pages trying to understand how one component is constructed and what are the parameters that will appear on the configuration.yaml.
My idea should to add another module to the one I modified. So similar to rpi_gpio, but it will do just a pulse and record the state on, unless another event will modify it.
The module will consist on turn the switch on for a customizable period an the turn it back off. All I found is just toggle, but a momentary switch I’m not able to get anything closer.
I read about to call a service which might act to change the state from on to off in a short while, but I doubt it will go less than a second, which HA time base. Anyway is not that suitable when a module can manage it in a smarter way (I think).
I do expect that when tapping on the Lovelace icon the GPIO will go from OFF>ON-period>OFF.
Your script gives me an idea, but I don’t expect to use a GPIO as event input. Probably in a next step I’ll need this way too.
As you mention I don’t have an entity input_boolean in my list.
You can define the input_boolean yourself in the configuration.yaml and use it as a UI switch input for automations and/or manipulate it via other automations.
Sorry to disagree…
AFAIK it should work that the picture card (as I’m using) will call a service on tapping the image and the service should activate a script like that one you showed above.
Now, the point is that I don’t know yet how this it will accomplish. It look trollish, somehow, but really I have a little knowledge to program yaml, in the way HA requires.
