I’m running HASS in a virtualenv. I’ve set up a miflora plant sensor but no data is received. Having a look at /var/log/daemon.log shows that gatttool could not be found. This is the necessary tool that reads the data from sensor: Feb 10 21:06:57 schneekluth hass[31099]: /bin/sh: 1: gatttool: not found
When running demo.py using this library data is correctly received from miflora sensor:
Getting data from Mi Flora
FW: 2.8.6
Temperature: 18.0
Moisture: 9
Light: 136
Conductivity: 69
Battery: 87
The sensor itself if working fine but it wont work with HASS. Can anybody help with this issue?
Got it working! It’s basically the same issue I had with my nmap tracker in my virtualenv installation.
To get the sensor working and gatttool executed successfully just edit this file: /srv/homeassistant/lib/python3.4/site-packages/miflora/miflora_poller.py
and add full path to gatttool (/usr/bin/gatttool) in the functions def write_ble in line 47 and def read_ble in line 106 for example:
while attempt <= retries:
cmd = "/usr/bin/gatttool --device={} --char-read -a {} --adapter={}".format(mac, handle, adapter)
I’d also point to these useful debugging commands that helped a lot while troubleshooting the mi flora plant sensor:
Final Question:
I basically don’t understand why my virtualenv constantly needs full path for components involving the shell. I’ve installed Homeassistant according to the installation instructions but with every update I have to readd the full path to the corresponding files. It is a little annoying. Can anyone help me out with this? Is there something wrong with my virtualenv?
