I don’t understand the mistake…
Where is the problem?
Source:
automation.yaml
- id: Wohnzimmer Dining Motion Sensor
alias: Wohnzimmer Dining Motion Sensor
- platform: state
entity_id: sensor.wohnzimmer_motion_sensor
to: 'on'
condition:
- condition: time
after: '23:00:00'
before: '06:00:00'
- service: script.turn_on
entity_id: script.wohnzimmer_motion
script.yaml
wohnzimmer_motion: !include scripts/wohnzimmer_motion.yaml
wohnzimmer_motion_sensor_timer: include scripts/wohnzimmer_motion_sensor_timer.yaml
alias: Wohnzimmer Motion Sensor
sequence:
- service: script.turn_off
entity_id: script.wohnzimmer_motion_sensor_timer
- service: light.turn_on
entity_id: light.wohnzimmer
brightness: 255
color_temp: 500
xy_color: [0.1572,0.2044]
entity_id: script.wohnzimmer_motion_sensor_timer.yaml
alias: Wohnzimmer Motion Sensor Timer
sequence:
- delay:
minutes: 1
- service: light.turn_off
The Error is:
2017-11-18 18:07:25 ERROR (MainThread) [homeassistant.config] Invalid config for [script]: expected a dictionary for dictionary value @ data['script']['wohnzimmer_motion_sensor_timer']. Got 'include scripts/wohnzimmer_motion_sensor_timer.yaml'. (See /config/configuration.yaml, line 140). Please check the docs at https://home-assistant.io/components/script/
2017-11-18 18:07:25 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Invalid config.
Thanks for your Help!
