Hello, i have some iframe ip adress “!secret” inside my lovelace yaml and they are not loading in the ui. Before the update it was working.
Does anyone have the same problem?
Thanks.
Thanks.
In the breaking changes it tells you that !secrets and ! include are not supported using the GUI but I believe if you switch to yaml mode you can still use them
Lovelace is already in yaml mode, that’s strange.
After the last update it’s working.
Solved
