alias: New automation
description: ""
- platform: time
at: "00:00:00"
condition: []
- service: calendar.get_events
metadata: {}
start_date_time: "{{ now().strftime('%Y-%m-%d 00:00:00') }}"
end_date_time: "{{ (now() + timedelta(days=1)).strftime('%Y-%m-%d 23:59:59') }}"
entity_id: calendar.garbage
response_variable: events
- service: notify.notify
metadata: {}
title: GAAAAAAAAAAAAAAAA
message: |
ciao {% for entity in events %}
- {{ entity.attributes.summary }}\n
{% endfor %}
mode: single
Hi folks, i am trying to make an automation that sends a notification with the list of all the events for the next day and i have been sitting here for hours trying to do it and this is the closest i got to it all the help is apricieted.
You need to specify the calendar in your template since the response variable events
returns a complex object.
metadata: {}
message: |
ciao {% for entity in events['calendar.garbage'].events %}
- {{ entity.summary }}\n
{% endfor %}
FWIW, it is not advisable to use notify.notify
if you have more than 1 notifier, since the results may be unpredictable.
EDIT: Removed extra data
key .
Thanks for the reply but unfortunally like before i don-t even recive the notificatrion and since the variable is defined in a different action i can-t test it to look at errors
i found out that in the log book i can see the error and it is returning this:
You had an extra data
key in your original that I failed to remove. I have corrected it above.
LucaCraft89
(Luca Dall'Acqua)
October 3, 2024, 7:26am
6
After a While of banging my head against the wall i manages to make it work, you just need a help TextBox somowere and a script like the following:
Automation.yaml:
description: ""
- platform: time
at: "18:00:00"
condition: []
- action: script.1712084337964
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
- action: notify.notify
title: Raccolta Spazzatura Domani
message: |
{{states('input_text.giovanni')}}
mode: single
Script.yaml:
alias: get calendar events and notify
sequence:
- action: input_text.set_value
metadata: {}
value: " "
entity_id: input_text.giovanni
- action: calendar.get_events
start_date_time: "{{ (now() + timedelta(days=1)).strftime('%Y-%m-%d 00:00:59') }}"
response_variable: eventss
value: |
{% for entity in eventss['calendar.garbage'].events %}
- {{entity.summary}}{{- '\n' -}}
{% endfor %}
TextBox:
input_text.giovanni
