(SOLVED) Strange behaviour automation editor
Hi All,
I see all my automations in the list. But 1 is act strange.
Control - Nest Control Someone Home
the one that is active, I can disable it and enable it.
The other 2 when enabled goes directly to disable. But basic they must not be there at all.
09
How can I solve this?
Tried remove them already from the core.restore_state without effect
You can go into your automation yaml and delete the lines which you want to delete
I don’t now what happen. After couple of reboots (edit and create new scripts) the problem was solved yesterday.
