So I am monitoring my ZWave lock with a zwave_js_notification as the trigger that’ll send a notification when a specific key code slot was used. Basically I templated out the message porting of a notify service call to map the received slot ID from the zwave_js_notification trigger to a desired display string. However it seems to be failing all the time and not picking a string even though the trigger’s event data shown from the trace has the correct value I’m looking for. Since I’m a templating newbie, can someone take a look at my template and tell me what I am doing wrong?
service: notify.mobile_app
message: >
{% set names = {
'251':'Slot 251',
'1':'Slot 1',
'2':'Slot 2',
'3':'Slot 3'
{{ names[trigger.event.data.parameters.userId] }} opened the front door with the keypad.
And here is the trigger’s data from the last automation execution trace.
this:
entity_id: automation.front_door_unlocked_notification
state: 'on'
attributes:
last_triggered: '<Some Value>'
mode: single
current: 0
friendly_name: Front Door Unlocked Notification
last_changed: '<Some Value>'
last_updated: '<Some Value>'
context:
parent_id: <Some Value>
user_id: null
idx: '0'
alias: null
platform: event
event:
event_type: zwave_js_notification
domain: zwave_js
node_id: 158
home_id: 4162111339
device_id: <Some Value>
command_class: 113
command_class_name: Notification
label: Access Control
type: 6
event: 6
event_label: Keypad unlock operation
parameters:
userId: 251
origin: LOCAL
time_fired: '<Some Value>'
context:
parent_id: null
user_id: null
description: event 'zwave_js_notification'
