Hi group,
I was following the installation steps in https://www.home-assistant.io/hassio/installation/. However, I was stuck at this stage:
I’m using Raspberry Pi 4 with a 32GB SD card. What I’ve done with the installation:
- download the recommended HassOS 32-bit image for RPi4 in the link.
- Flash the SD card with the image.
- Insert the SD card to RPi 4 and power on it with monitor, keyboard and mouse plugged in.
- Press an Enter when the screen stuck. Then it starts to ask “homeassistant login:”
I didn’t input any information about my wifi or etc, so I’m assuming it has not downloaded downloads the latest version of Home Assistant as mentioned in the installation instruction.
Also, from some online resources, the home assistant account creation seems to via web browser instead of the command line in the booting screen. I’ve tried to login with my forum account info and it showed “Login incorrect” (I don’t think it should be this account anyway because it cannot connect to the internet for account validation).
So could anyone provide any information that how I could solve the problem or whether I’m on the correct path to install HomeAssistant? Thanks!
