------ duh… forgot to change the host ip address in the port forwarding section of the router…
hope that helps.
hi,
all of a sudden i cant reach the frontend of my Hassio setup anymore.
duckdns wont go to my Hassio (it does have the correct external i address of my router), and when i try to login locally on Hassio etc, it keeps showing loading data…
If i reboot, i do see the startup automations kickin, even hear Morgan Freeman welcoming me home
meaning the system did reboot and is running.
i can ssh in and see the log with this main issue:
2018-03-24 16:14:56 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 142, in _async_setup_component
result = await component.async_setup(hass, processed_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 397, in async_setup
success = await hass.data[DATA_MQTT].async_connect() # type: bool
File "/usr/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 519, in async_connect
self._mqttc.connect, self.broker, self.port, self.keepalive)
File "/usr/lib/python3.6/asyncio/futures.py", line 332, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/paho/mqtt/client.py", line 768, in connect
return self.reconnect()
File "/usr/lib/python3.6/site-packages/paho/mqtt/client.py", line 895, in reconnect
sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
File "/usr/lib/python3.6/socket.py", line 724, in create_connection
raise err
File "/usr/lib/python3.6/socket.py", line 713, in create_connection
sock.connect(sa)
OSError: [Errno 113] Host is unreachable
i did reboot the rpi host, and the router because of a firmware upgrade, which changed the base ip address. I changed that in the mosquitto setup of my mqtt publisher, so that should have taken care of that?
Please help, i have no clue what i must be looking for now…how can i test if the rpi has internet connection? it is seen on the router, and network.
Cheers,
Marius
