My Supervisor is running in an unhealthy state.
Latest version is 2020.12.7, but installed is 2021.01.dev0801.
I think this was my watchtower container which updated the supervisor.
I disabled it, deleted the supervisor container and hassio recreated it immediately, but again the newest dev version…
How can I get the right supported one installed again?
Unhealthy Home Assistant because of watchtower.
If the Supervisor logs (Frontend > Supervisor > System) reports that you have containers that are not supported, you need to remove the images from the host.
In my case I was running containrrr/watchtower .
To remove it, on the host execute:
docker rmi containrrr/watchtower:latest
If you’re running Portainer this can be done under Images .
Then restart Supervisor (Frontend > Supervisor > Restart). After a minute, if you reload the page, the unhealthy state should be gone
