[SOLVED] Switch off triggering button entity
Hello!
I setup Wake on LAN as a switch and it works as expected.
However, I want to make the off part of the switch, turn off my PC; I have a separate button which already does this as I am using windows HASS.Agent and works great.
I just wondered if anyone can help me with the config for getting the off side of the switch to run this entity?
There’s an example in the documents:
switch:
  - platform: wake_on_lan
    turn_off:
      service: # put whatever service your off button calls here.
It would have helped if you had included the configuration of both your WoL switch and button in your post.
Hi Tom,
I tried this but didnt work, I get the error Failed to call service switch/turn_off. Unable to find service button.morgan_pc2_shutdown
I’m probably making a really simple and stupid mistake as I’m only 72 hours into using home assistant but this was my switch config (censored mac address just incase):
wake_on_lan:
switch:
    mac: **-**-**-**-**-**
    turn_off:
      service: button.morgan_pc2_shutdown
That isn’t a service. It is an entity. This is a service:
    turn_off:
      service: button.press
        entity_id: button.morgan_pc2_shutdown
