poudenes
(Poudenes)
May 8, 2022, 10:23am
1
Hi All,
sensor.livingroom_lux
have state 11726.0
“{{ states(‘sensor.livingroom_lux’) > ‘100’ and states(‘sensor.livingroom_lux’) < ‘220’ }}”
result: TRUE
That is not correct because yes its bigger then 100 but not lower then 220
What do I not see at this simple template line?
Want replace:
condition: numeric_state
entity_id: sensor.livingroom_lux
above: 100
below: 220
to
condition: "{{ states('sensor.livingroom_lux') > '100' and states('sensor.livingroom_lux') < '220' }}"
tom_l
May 8, 2022, 10:30am
2
You are comparing strings. Try it with numbers.
"{{ 200 > states('sensor.livingroom_lux')|int > 100 }}"
poudenes
(Poudenes)
May 8, 2022, 10:32am
3
To understand this line:
now its check if 200 is greater then the sensor state. and last one if sensor state is greater then 100?
Result is FALSE now
tom_l
May 8, 2022, 10:34am
4
It checks if your sensor is between 100 and 200.
poudenes
(Poudenes)
May 8, 2022, 10:36am
5
Thanks. Will archive this so I will never forget it
poudenes
(Poudenes)
May 8, 2022, 10:46am
6
little offtopic question then
I checked other automations and this one is working
"{{ states('sensor.bathroom_humidity') < '60' }}"
change to this give same result
"{{ states('sensor.bathroom_humidity') | int < 60 }}"
What is the difference when use int
tom_l
May 8, 2022, 11:04am
7
States are strings. |int
converts the string to an integer (number with no decimal part). |float
converts the string to a number with a decimal fraction.
You were just lucky that when comparing strings you got the right result. This is not guaranteed unless the strings are the same length.
Put this in the template editor:
{{ '60' > '7' }}
{{ '60' > '07' }}
{{ int('60') > int('7') }}
{{ 60 > 7 }}
poudenes
(Poudenes)
May 8, 2022, 11:22am
8
Funny output…
false
true
true
true
Only the first one gives a funny result. For me its logic that 60 is larger then 7
But seems that its remove the 0 then its lower then 7
tom_l
May 8, 2022, 11:34am
9
It is exactly what is expected. The numbers with quotes around them are not numbers . They are strings . They are not compared the way numbers are.
More for you to try:
{{ 'foo' > 'bar' }}
{{ 'foo' > 'rab' }}
poudenes
(Poudenes)
May 8, 2022, 11:43am
10
How does this work. f is higher then b but not higher then r?
poudenes
(Poudenes)
May 8, 2022, 11:49am
12
thank you so much for this very clear way to explain how it work!
I will check my automations, and correct them when needed !
123
(Taras)
May 8, 2022, 11:50am
13
ASCII Table
String comparisons use the character’s ASCII code.
The ASCII code for b
is higher than a
so 'a' > 'b'
is false
