[Solved] Template Sensor convert file sizes bytes to KB to MB
Hi everybody,
could somebody please help me how I need to setup a template sensor to display my up- and download speeds in KB/s or when appropriate in MB/s? Currently the sensor reports the rates in bytes which is not very useful to me. I guess I need to convert the bytes to KB or MB and the also change the unit of measurement when a threshold is reached and this exercise currently exceeds my knowledge.
For what its worth I am using the fritzbox Netmonitor sensor which reports the current speeds in bytes/s.
Thanks for you help!
Something like this
{{ states.sensor.bytes_sent | filesizeformat() }}/s
Oh brilliant! Thank you so much for your fast reply and superb help!
Hello, I am a new user of HA I also have a problem with conversion to Mb / s
where exactly should I put this line to work?
{{states.sensor.bytes_sent | filesizeformat ()}} / s
i’m converting from bytes to mb with this code below:
    sensors:
      bytes_received:
        friendly_name: "MB Received"
        unit_of_measurement: 'MB/s'
        value_template: "{{ states('sensor.archerc7v4_bytes_received')|float / 1048576 }}"
      bytes_sent:
        friendly_name: "MB Sent"
        value_template: "{{ states('sensor.archerc7v4_bytes_sent')|float / 1048576 }}"
How can I round the result to a whole number
Have you tried piping it to round like so?:
value_template: "{{ states('sensor.archerc7v4_bytes_sent')|float / 1048576 | round(0) }}"
thank you for your help, unfortunately still not working
      bytes_sent:
someone has an idea to solve this issue?
I guess you need to realize what you are cutting off, in your case 1048576 is only stripped.
You probably want to have your whole calculation stripped of like this example:
“{{ (states.sensor.fritz_router.attributes.bytes_sent | float / 1073741824) | round(2) }}”
confused:
sensors:
      bytes_received:
        value_template: "{{ states('sensor.frlmx_b_received')|float / 1073741824 | round(2) }}"
      bytes_sent:
        value_template: "{{ states('sensor.frlmx_b_sent')|float / 1073741824 | round(2) }}"
grafik
pipes “|” take priority so what you are doing is rounding 1073741824
which surprisingly is 1073741824
use more brackets
ok, but where should I use the brackets?
I’m not sure if you are kidding but …
  • states(‘sensor.frlmx_b_sent’) | float
    (putting spaces in makes it easier to read) takes the value (state) of sensor.frlmx_b_sent and casts it to float (makes a text string into a number value with decimals) This is the first calculation
  • 1073741824 | round(2)
    Takes 1073741824 and casts it to round(2) 2 decimal places, but it has no decimal places so it stays as it is - second calculation
  • float_value / rounded_value
    (\ is way down the pecking order) just divides float_value by 1073741824 third calculation
So you need to add brackets to shift the priorities, so that you | round(2) last of all
So : -
“{{ (states(‘sensor.frlmx_b_sent’) | float / 1073741824) | round(2) }}”
This moves the second calculation to “divide by 1073741824”
Each of these are ‘operations’ not strictly ‘calculations’ as changing something from text to a number is a grey area - calculation wise
Thank you, and sorry I am not kidding because I am a bloddy beginner.
The sensor brings this resulat at the moment:
grafik
a doublecheck of the entity from fritzbox show
grafik
So, I think the value 2,22 MB/s is not correct
Okay,
You know that these are decimal representaions of binary numbers ?
1,2,4,8,16,32,64,128,256,512,1024 etc (shortcut 2^n)
So a Kilo (1000) bit is 1024
So strictly speaking k to M should be divided by 1024
I have no Idea where you got 1073741824 from (but that was NOT the question you asked)
This is hard for some people to understand so they have ‘decimalised’ binary numbers and it is quite common to see Mb * 1000 = kb (thats Mb = kb / 1000)
If you don’t like the answer - change the divisor
you are absolutly right, 1073741824 bytes = 1 GB
Yes but
kb / 1,073.741824 does not equate to Mb
What level did you complete Maths to ?
sensor.frlmx_b_sent = bytes / 1073741824 = …GB
As I said it depends
see : -
