[SOLVED]Theme Background not working with https
Hi all,
Hope this is the right place to ask.
I am using a theme that is using a background that is defined in the theme file.
background-image: 'center / cover no-repeat url("/local/day_ha_background.jpg") fixed'
When I connect using the ip address of HA The background is correctly displayed.
Recently I install traefik and use my own domain with let’sencrypt.
When I connect via https then the background stays white whatever I do.
Is there any logs I should be looking to see what the problem is?
I found the problem.
For some reason the theme in my user setting was set to default rather than backend-select (as it was before)
Once updated my automation is able to change the theme as required
