[SOLVED] "thread has died - thread will be restarted" loop
I’m having some issues with at least two apps that, under certain “as of yet not completely known” conditions results in an endless loop of:
2022-06-03 15:18:11.948322 CRITICAL AppDaemon: Thread thread-5 has died
2022-06-03 15:18:11.949037 CRITICAL AppDaemon: Pinned apps were: ['car_charge_automation']
2022-06-03 15:18:11.949872 CRITICAL AppDaemon: Thread will be restarted
2022-06-03 15:18:11.950457 INFO AppDaemon: Adding thread 5
2022-06-03 15:18:11.951699 CRITICAL AppDaemon: Thread thread-19 has died
2022-06-03 15:18:11.952173 CRITICAL AppDaemon: Pinned apps were: ['dishwasher_finished']
2022-06-03 15:18:11.952677 CRITICAL AppDaemon: Thread will be restarted
2022-06-03 15:18:11.953380 INFO AppDaemon: Adding thread 19
With my (documented) difficulty understanding timers, I’m kind of suspecting that might be the culprit. I did see something similar in a different thread, but I don’t think the suggestion there is relevant for the first one (car_charge_automation).
For the second (dishwasher_finished), there was something suspiciously similar, namely:
self.power_timer = self.run_in(self.who_and_when(old=old, new=new), 900)
I have tried a few different ways of doing this now, but nothing so far that has worked for me.
I think they work; I get the expected notification, but then the loop starts, and I’m assuming they won’t work again while that’s happening?
AppDaemon script for "car_charge_automation"
import datetime
import hassapi as hass
import globals
class CarCharger(hass.Hass, globals.Entities, globals.Functions):
    def initialize(self):
        self.start_time = None
        self.automate_off_timer = None
        self.charge_time = 3 # Number of hours for full charge. Change with new car.
        self.finish_time = 7 # What time in the morning to finish.
        self.automate(None, None, None, None, None)
        self.listen_state(self.automate, self.nordpool["current_price"], attribute = "tomorrow", old= 24 * [None])
        self.listen_state(self.automate, self.nordpool["current_price"], attribute = "tomorrow", old= [])
        self.listen_state(self.automate, self.automation_control["car_charger"], new="on")
        self.listen_state(self.automate, self.edgeos["kia_niro"], new="on")
        self.run_daily(self.automate(None, None, None, None, None), "22:00:00")
        self.listen_event(self.charge_now, "CAR_CHARGER")
        # self.listen_event(self.automate, "SET_CAR_CHARGER") # Covered by turning off, then on the boolean.
    def automate(self, entity, attribute, old, new, kwargs):
        Determine whether the charger should be automated.
        If yes, run scripts to determine when if the prices for tomorrow are
        available.
        Otherwise turn off, and the listen_state for that attribute will run
        when it is populated by a list of prices (instead on [None]).
        if self.get_state(self.automation_control["car_charger"]) == "on":
            on_time = self.determine_cheapest_time()
            self.toggle_charge_state(on_time)
    def determine_cheapest_time(self):
        Determine the best time to start charging.
        There should probably be a limit that it won't do so before the nordpool
        sensor has prices for tomorrow.
        today = self.get_entity(self.nordpool["current_price"]).get_state(attribute="today")
        tomorrow = self.get_entity(self.nordpool["current_price"]).get_state(attribute="tomorrow")
        now = self.get_state("sensor.time")
        now_hour = int(now.split(":")[0])
        today_from_now = today[now_hour:]
        today_and_tomorrow = self.wait_for_tomorrow_prices(today, tomorrow, today_from_now)
        today_datetime = datetime.date.today()
        tomorrow_datetime = datetime.date.today() + datetime.timedelta(1)
        if today_and_tomorrow != []: # Finds the index, t = i, corresponding to the start time/cost that yoields the cheapest 3 cosecutive hours ending before 07:00.
            p = 100
            t = None
            for i in range(len(today_and_tomorrow) - (self.charge_time - 1)):
                p1 = 0
                for j in range(self.charge_time):
                    p1 += today_and_tomorrow[i + j]
                if p1 < p:
                    p = p1
                    t = i #  t is an index in the list of prices per hour starting at current time, and going until midnight if not tomorrow times available, or until self.finish_time if they are.
            what_time = t + now_hour # get the hour of the day to start.
            if what_time >= 24:
                on_time = datetime.datetime.combine(tomorrow_datetime, datetime.time(what_time - 24, 0))
            else:
                on_time = datetime.datetime.combine(today_datetime, datetime.time(what_time, 0))
            return on_time
    def wait_for_tomorrow_prices(self, today, tomorrow, today_from_now):
        Determine whether to wait for tomorrows prices.
        If plugging in after midninght, but before 07:00, don't wait.
        if self.now_is_between("00:00:00", "08:00:00"):
            return today_from_now
        elif len(tomorrow) == 24:
            try:
                float(tomorrow[1]) # Sometimes I've seen 24 * None
                return today_from_now + tomorrow[:self.finish_time]
            except:
                self.turn_on(self.car_charger["sleep_mode"])
                return []
        else:
            return []
    def toggle_charge_state(self, on_time):
        connected_states = ["charging", "connected"]
        now_datetime = self.get_now()
        if self.get_state(self.car_charger["station_status"]) in connected_states:
            if on_time >= datetime.datetime.now():
        data = {"tag": "car_charger_notification"}
        self.call_service(self.notify_phones["walden"], message="Car Charger set for " + str(on_time), data=data)
        if self.start_time: # Recommended here: https://community.home-assistant.io/t/cancel-timer-reporting-invalid-callback-handle/426416/2
            if self.timer_running(self.start_time):
                self.cancel_timer(self.start_time)
        try:
            self.start_time = self.run_at(self.start_charging, on_time) # Can do if event is not in the past.
        except:
            self.start_charging(None) # If on_time was in the past, just start now.
        state, attributes = self.future_events()
        try:
            attributes["car_charging"] = on_time
        except:
            attributes = {"car_charging": "not set"}
        self.set_state("binary_sensor.future_events", state="on", attributes=attributes)
    def start_charging(self, kwargs):
        self.turn_off(self.car_charger["sleep_mode"])
    def charge_now(self, event_name, data, kwargs):
        if self.automate_off_timer: # Recommended here: https://community.home-assistant.io/t/cancel-timer-reporting-invalid-callback-handle/426416/2
            if self.timer_running(self.automate_off_timer):
                self.cancel_timer(self.automate_off_timer)
        # if self.automate_off_timer != None:
        #     self.cancel_timer(self.automate_off_timer)
        self.turn_off(self.automation_control["car_charger"])
        self.automate_off_timer = self.run_in(self.turn_on_automation, 10800)
    def turn_on_automation(self):
        self.turn_on(self.automation_control["car_charger"])
    def notify_if_not_charging(self):
        pass
AppDaemon script for "dishwasher_finished"
import globals
class Appliances(hass.Hass, globals.Entities, globals.Functions):
        self.notification_timer = None
        self.power_timer = None
        self.listen_state(self.timer_function, self.power_sensors["dishwasher"])
    def timer_function(self, entity, attribute, old, new, kwargs):
        Check that the dishwasher power consumption is "low", and stays there upon next state update.
        if 20 > float(old) > 10 and float(new) < 5:
            if self.power_timer == None:
                self.power_timer = self.run_in(self.who_and_when(old=old, new=new), 900) #900
    def who_and_when(self, **kwargs): #(self, old, new):
        Check whether the dishwasher is finished (dropping below 5 W).
        Determine who is home to empty it.
        home = []
        old = kwargs["old"]
        new = kwargs["new"]
        if self.get_state(self.device_trackers["emilie"]) == "home":
            home.append("emilie")
        if self.get_state(self.device_trackers["naia"]) == "home":
            home.append("naia")
        if self.get_state(self.device_trackers["kristina"]) == "home":
            home.append("kristina")
        if self.get_state(self.device_trackers["walden"]) == "home":
            home.append("walden")
        self.notify(home, old, new)
        # if len(home) > 0:
        #     if self.awake():
        #         # self.notify(home, old, new)
        #         self.notify(home)
        #     else:
        #         today = self.get_entity(self.workday["actual"]).get_state(attribute = "workday_today") == "on"
        #         tomorrow = self.get_entity(self.workday["actual"]).get_state(attribute = "workday_tomorrow") == "on"
        #         if self.now_is_between("19:30:00", "00:00:00") and tomorrow:
        #             self.notification_timer = self.run_at(self.notify(home, old, new), "07:15:00")
        #         elif self.now_is_between("19:30:00", "00:00:00") and not tomorrow:
        #             self.notification_timer = self.run_at(self.notify(home, old, new), "10:00:00")
        #         elif self.now_is_between("00:00:00", "07:15:00") and today:
        #         elif self.now_is_between("00:00:00", "10:00:00") and not today:
    def notify(self, home, old, new):
        who = home[0]
        notify_who = self.notify_phones[who]
        kids = ["emilie", "naia", "luca"]
        today = self.get_entity(self.workday["actual"]).get_state(attribute="workday_today") == "on"
        tomorrow = self.get_entity(self.workday["actual"]).get_state(attribute="workday_tomorrow") == "on"
        self.call_service(
            message = "Opvaskemaskinen er klar til at blive tømt. \nNotify_Who = " + str(notify_who) + ". \nHome = " + str(home) + ".\n old, new = " + str(old) + ", " + str(new)
        # self.call_service(
        #     notify_who,
        #     message = "Opvaskemaskinen er klar til at blive tømt"
        # if home[0] in kids:
        #     if any((
        #         all(
        #             tomorrow, self.now_is_between("12:00:00", "20:30:00")
        #         all(
        #             today, self.now_is_between("08:00:00", "12:00:00")
        #         all(
        #             not tomorrow, self.now_is_between("12:00:00", "21:30:00")
        #         all(
        #             not today, self.now_is_between("10:00:00", "12:00:00")
        #         self.speak()
        title = "Opvaskemaskinen skal tømmes!"
        message = ", opvaskemaskinen er klar til at blive tømt. Husk at starte den igen hvis du fylder den."
        if len(home) > 0:
            pass
            # self.call_service(self.notify_phones[who], title=title, message=who.capitalize() + message)
        else:
            people_to_empty = ["naia", "emilie", "kristina", "walden"]
            for device in people_to_empty:
                self.someone_coming_home = self.listen_state(self.message_when_home, self.device_trackers[device])
        #     "notify/" + self.notify_devices["walden_phone"],
    def message_when_home(self, entity, attribute, old, new, kwargs):
        home = [key for key, val in self.device_trackers.items() if entity == val][0]
        self.call_service(self.notify_phones[entity], title=title, message=home.capitalize() + message)
        self.cancel_listen_state(self.someone_coming_home)
    def speak(self):
        self.call_service(
            "tts/google_translate_say",
            entity_id=self.speakers["top_floor_speaker"],
            message="Opvaskemaskinen er klar til at blive tømt",
            language="da"
if you get those messages, the only thing you can do is restart AD. and indeed it doesnt work anymore at that time.
i did take a short look at the code, but its to much to see a clear cause.
its possible that you change the state from an entity that then triggers an action in the app and it starts looping.
my advise:
add logging, add logging and add more logging.
at the beginning from each function, at the end from each function, after you did retrieve a state, etc.
the more the better.
and then when the app has crashed, look at your logs to see what went wrong.
without logging your driving blind.
and a simple explanation from timers:
self.handler = self.run_in(self.some_cb, 60) does the following:
in a list with all timers there is a record added.
id                                               -  callback                 - time
the number that you find in the self.handler var - the function self.some_cb - the calculated start time
every second AD looks at that list to see if a callback should be triggered.
when its activated its taken from the list
and when you have saved the id (so when you used self.handler = ) then you can use that ID to cancel the timer or to see info about it.
AD doesnt know if you saved the ID or not. so
does the exact same thing as
self.handler is just a normal variable where you store the id if you want to use it later on. (to cancel or retrieve info)
i hope that makes it more clear.
Logs do help a bit:)
To me it looks like the run_in() runs immediately, not after the duration specified.
In the “simpler” of the apps above (diswasher_finished) I see that adding some logging in the first function:
        self.log("Dishwasher TIMER FUNCTION", log="diag_log")
            self.log(self.power_timer, log="diag_log")
                self.power_timer = self.run_in(self.who_and_when(old=old, new=new), 5) #900
                self.log("TIMER - AFTER TIMER SET", log="diag_log")
Gives logs that make me think it’s not waiting the 5 seconds before running the next function (self.who_and_when()). See my comment at end of log line (third line shouldn’t log until 5 seconds after the first two?):
logs:
2022-06-04 13:49:13.104683 INFO dishwasher_finished: Dishwasher TIMER FUNCTION <-- logged in timer_function()
2022-06-04 13:49:13.105444 INFO dishwasher_finished: None <-- logged in timer_function()
2022-06-04 13:49:13.107449 INFO dishwasher_finished: Dishwasher WHO AND WHEN <-- logged in who_and_when(). Should not log until 5 seconds after timer_function()??
2022-06-04 13:49:13.108040 INFO dishwasher_finished: None <-- logged in who_and_when(). Should not log until 5 seconds after timer_function()??
2022-06-04 13:49:13.118976 INFO dishwasher_finished: Dishwasher NOTIFY <-- logged in notify(). Should not log until 5 seconds after??
2022-06-04 13:49:13.119746 INFO dishwasher_finished: None <-- logged in notify(). Should not log until 5 seconds after??
2022-06-04 13:49:13.141171 INFO dishwasher_finished: TIMER - AFTER TIMER SET <-- logged in timer_function(), but on the line AFTER the self.run_in()
2022-06-04 13:49:13.144082 INFO dishwasher_finished: e01101d172e0446ab7b39b38893eb71f <-- logged in timer_function(), but on the line AFTER the self.run_in(). Now the timer is set.
I do also get something in the logs that I can see when writing to a file (they were hidde by all the new entries about thread restarting when just looking at STDOUT):
2022-06-04 13:47:36.746321 INFO AppDaemon: App initialization complete
Exception in thread thread-19:
  File "/usr/lib/python3.9/threading.py", line 973, in _bootstrap_inner
    self.run()
  File "/usr/lib/python3.9/threading.py", line 910, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/lib/python3.9/site-packages/appdaemon/threading.py", line 891, in worker
    callback = "{}() in {}".format(funcref.__name__, name)
AttributeError: 'NoneType' object has no attribute '__name__'
2022-06-04 13:49:18.079434 CRITICAL AppDaemon: Thread thread-19 has died
2022-06-04 13:49:18.080816 CRITICAL AppDaemon: Pinned apps were: ['dishwasher_finished']
2022-06-04 13:49:18.081197 CRITICAL AppDaemon: Thread will be restarted
2022-06-04 13:49:18.081631 INFO AppDaemon: Adding thread 19
I did also notice that during AppDaemon startup, it logs:
2022-06-04 13:47:36.331654 WARNING HASS: Error calling Home Assistant service default/homeassistant/turn_off
2022-06-04 13:47:36.332323 WARNING HASS: Code: 500, error: 500 Internal Server Error
Server got itself in trouble
But doesn’t say which app is doing something wrong. I don’t think it’s related (since I don’t call any turn_off, just wanted to mention in case it’s important.
Update: It was mainly that I was passing (and/or “receiving”) arguments in a wrong way when using any of the timed functions like run_in, run_at.
For the diswasher_finished, I think it was because I used **kwargs instead of kwargs in a app definition; changing
to
    def who_and_when(self, kwargs):
stopped the restart loop.
For the car_charge_automation, it was the part run_daily under initialize it didn’t like. I think you can’t/shouldn’t pass positional arguments through that.
I solved it by writing a “dummy” function:
    def daily_wrapper(self, kwargs):
and changing the run_daily to
        self.run_daily(self.daily_wrapper, "23:35:00")
And the
2022-06-04 23:20:47.935718 WARNING HASS: Error calling Home Assistant service default/homeassistant/turn_on
2022-06-04 23:20:47.936531 WARNING HASS: Code: 500, error: 500 Internal Server Error
Looks like a HACS integration that needed to be updated to a beta version to be compatible with Hass Core 2022.6.
So I think it’s all sorted out. If not, I’ll update, i case anyone stumbles on this thread for answers.
indeed you cant use
self.run_in(self.cb(anything), 60)
because then you place a function where it should be a callback.
so it should be
self.run_in(self.cb, 60, anything = anything)
and that goes for all functions like run_in, run_at, run_every, listen_state, etc.
the name kwargs in the callback is actually chosen wrong in the past.
it is actually
def callback(self, my_transport_dict):
for passing variables to the callback you can use:
    self.run_in(self.callback, 60, my_var = "something")
    self.run_daily(self.callback, time, my_var = "something else")
def callback( self, my_transport_dict): # you can still use kwargs as name there
    my_var = my_transport_dict["my_var"]
for your error during startup: HA probably hasnt all its services ready when AD starts up.
that can be changed by adding a delay to the HA plugin in the appdaemon.yaml
