SOLVED: Trying to display the state of a switch in ESPHOME display
Hi All
I have a switch that I would like to display in the lambda in esphome if it’s on or not.
I’ve tried to just use the switch directly, but is that possible? Or do I need to create a sensor that holds the state of the switch to be able to display the state?
This is the config I have so far:
substitutions:
  device_name: kitchendisplay
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "ssid"
  password: "pw"
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
ota:
  password: "pw"
text_sensor:
  - platform: version
    name: "${device_name} ESPHome Version"
  - platform: wifi_info
    ip_address:
    ssid:
  - platform: homeassistant
    entity_id: switch.vandsten
    internal: true
  - platform: wifi_signal
    name: '${device_name} WiFi Signal'
    update_interval: 60s
    accuracy_decimals: 0
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    accuracy_decimals: 1
    filters:
      - multiply: 0.000011574
    entity_id: sensor.pool_temperature
    internal: true
time:
font:
  - file: "comic.ttf"
  - file: "calibrib.ttf"
  - file: "calibri.ttf"
spi:
  clk_pin: D0
  mosi_pin: D1
display:
  - platform: waveshare_epaper
    rotation: 90
    cs_pin: D2
    dc_pin: D6
    busy_pin: D7
    reset_pin: D5
    model: 2.90in
    full_update_every: 300
    lambda: |-
      it.printf(148, 0, id(headline), TextAlign::TOP_CENTER, "Fribert smarthome");
      it.strftime(296, 40, id(normaltext), TextAlign::BASELINE_RIGHT, "%H:%M", id(homeassistant_time).now());
      it.printf(0, 70, id(temptext), TextAlign::BASELINE_LEFT, "Pool:");
      it.printf(0, 120, id(temptext), TextAlign::BASELINE_LEFT, "Pump:");
      if (id(pooltemp).has_state()) {
        it.printf(220, 70, id(temptext), TextAlign::BASELINE_RIGHT, "%.1f°C", id(pooltemp));
      it.printf(220, 120, id(temptext), TextAlign::BASELINE_RIGHT, "%s", id(pumprunning).state.c_str());
But the pump state is not printing anything to the display.
Hmm, ok I made a template sensor, and that shows the state of the switch:
    sensors:
      pumprunning:
        friendly_name: "Is poolpump running"
        value_template: "{{ is_state('switch.vandsten', 'on' ) }}"
I then imported that in esphome:
binary_sensor:
    entity_id: binary_sensor.pumprunning
    internal: true
And finally I wanted it to print on/off with this line:
      if(id(pumprunning).state) {
        it.printf(140, 120, id(temptext), TextAlign::BASELINE_LEFT, "on");
      } else {
        it.printf(140, 120, id(temptext), TextAlign::BASELINE_LEFT, "off");
But no matter of the sensor state, it is shown as “off”.
And I don’t see anything update (not even the clock) unless I set the
Is that correct?
I’m running this in hass.io if that has any influence?
Ok, so I got a bit further, now it’s looking much better.
I made a binary sensor that showed the state of the switch.
I then import it to esphome.
The config looks like this:
binary_sensor:
    internal: true
    internal: true
time:
font:
spi:
  clk_pin: D0
  mosi_pin: D1
display:
    rotation: 90
    cs_pin: D2
    dc_pin: D6
    busy_pin: D7
    reset_pin: D5
    model: 2.90in
    full_update_every: 600
    lambda: |-
      it.strftime(6, 22, id(normaltext), TextAlign::BASELINE_LEFT, "%H:%M", id(homeassistant_time).now());
        it.printf(268, 70, id(temptext), TextAlign::BASELINE_RIGHT, "%.1f°C", id(pooltemp));
      } else {
        it.print(162, 70, id(temptext), TextAlign::BASELINE_LEFT, "offline");
        it.print(162, 117, id(temptext), TextAlign::BASELINE_LEFT, "on");
      } else {
        it.print(162, 117, id(temptext), TextAlign::BASELINE_LEFT, "off");
So it shows the state of the switch correctly.
But when it boots it shows the temperature as offline, but as soon as the temp sensor is polled, it gets an ‘unavailable’ , and that is converted to a 0, which is not what I would like, I would like it to show offline.
When I compile, I get this warning:
src/main.cpp: In lambda function:
src/main.cpp:546:83: warning: format '%f' expects argument of type 'double', but argument 7 has type 'esphome::homeassistant::HomeassistantSensor*' [-Wformat=]
it.printf(268, 70, bigtext, TextAlign::BASELINE_RIGHT, "%.1f°C", pooltemp);
Thank you for following through with this post. I used this to get the status of a couple switches displayed on my screen.
Hi.
Did you find a solution for the double warning??
edit:
I don’t know why (tried it several times!!), but this finaly works (whitout compile errors):
it.printf(20,4,id(font1), “%.1f°C”, id(current_temperature).state);
