The breaking changes indicated that TTS would be affected. The release note for that breaking change is: The TTS base_url
option is deprecated. Please, configure internal/external URL instead.
I have had voicerss working without issue for over a year, until this update. Voicerss does not have/use the base_url parameter. The voicerss documentation is not updated, with any changes that may apply to 2022.5…0
Anyone have any idea how to get TTS working again? I also tried google_translate, could not get it to work either.
Thanks!
[Solution]. The interesting thing for me, was that I was not getting errors in the log. In NodeRed, i was getting an API error when I tried to call the service with the text that was to be spoken. After carefully reading the debug message, I saw the problem. I ended up having to add media_source: to configuration.yaml and restarting to load the media_source integration. After doing this, it works again.
