Hello guys,
i like to receive a suggest about a simple project with my door garage.
Ive almost fininshed the setup step by step but i stopped on the curl part.
Wath i want to do:
On my home assistant ive setup a switch named “garage” that execute a simple command curl to invoke the “on” order on a Shelly 1 (out of my lan) via cloud.
So, ive built the curl string:
curl -X POST http://shelly-10-eu.shelly.cloud/device/relay/control -d "channel=0&turn=on&id=ABCDE1234&auth_key=ABCDE12345678"
Ive test the string via iphone shortcuts and an online tool (https://reqbin.com/curl).
It works perfectly.
Now the last step, how execute it from the switch "garage"on home assistant?
Trying adding this to configuration.yaml with no success:
I assumed the device wasn’t on the same network as HA, as the OP is using Shelly Cloud instead of a local IP, but yeah. If the integration’s an option it’s super-easy to use.
I’ll have to see if I can do this Cloud method with my own Shelly devices.
I’m sad to say, I pasted your command_line code into my config, modified it to turn my Shelly Dimmer on and off using Shelly Cloud and… it worked. I now have a dumb switch that turns my light on/off via Cloud.
I did notice that Shelly had a disclaimer in the Cloud API documentation that said they could move your user to another server at any time. You might want to check that your URI is still correct.
I hope Shelly don’t stuff you up by frequently changing your server. It would be nice if they provided a static URI that adapted to changes behind the scenes, but I suppose not enough people are using the Cloud API.
Hello everyone, i’ve manage to set 3 Shelly 1PM Plus that i have in a different network working in HA, but now i saw an issue, the state of shelly’s is not updated correcly after a status change.
