tried to update 0.84.2 to 0.84.4 virtual environment
full page of errors on download…
pip3 install --upgrade homeassistant
Looking in indexes: Simple index, https://www.piwheels.hostedpi.com/simple
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75cb8070>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75cb85b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75cb8030>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75cb8370>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75cb80d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75ca3f50>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75ca3630>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75ca3db0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75ca3e10>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)‘: /simple/homeassistant/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75ca3f10>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,)': /simple/homeassistant/
