I’m trying to create a sensor template which is sum up some other sensors.
For debugging purposes I was playing around with the templates section where I can test realtime.
Var 1: {{ states('sensor.PV_Eigenverbrauch_Aktuell') }}
Var 2: {{ states('sensor.PV_Power') }}
Sum: {{ states('sensor.PV_Eigenverbrauch_Aktuell') + states('sensor.PV_Power') }}
The result looks like:
Var 1: 0
Var 2: -2550
Sum: 0-2550
Does anyone know how I can bring jinja to sum up negative values?
to me it continued to give a negative value, I solved thanks to a user of the HA group on Discord in this way
value_template: "{{ states('sensor.produzione_istantanea') | int - states('sensor.consumo_istantaneo') | int if states('sensor.produzione_istantanea') | int - states('sensor.consumo_istantaneo') | int > 0 else 0 }}"
