Hi everybody,
I already had AppDaemon 0.0.12 installed and it did work just fine. I couldn’t update it to 0.0.13 so I made a bad decision and uninstalled it. Now I get an error in supervisor logs
17-08-27 12:20:45 INFO (SyncWorker_19) [hassio.dock.interface] Stop e5829d31/armhf-addon-appdaemon docker application
17-08-27 12:20:56 INFO (SyncWorker_19) [hassio.dock.interface] Clean e5829d31/armhf-addon-appdaemon docker application
17-08-27 12:20:59 INFO (SyncWorker_16) [hassio.dock.interface] Remove docker e5829d31/armhf-addon-appdaemon with latest and None
17-08-27 12:21:00 INFO (MainThread) [hassio.addons.addon] Remove Home-Assistant addon data folder /data/addons/data/e5829d31_appdaemon
17-08-27 12:21:36 INFO (MainThread) [hassio.addons.addon] Create Home-Assistant addon data folder /data/addons/data/e5829d31_appdaemon
17-08-27 12:21:36 INFO (SyncWorker_19) [hassio.dock.interface] Pull image e5829d31/armhf-addon-appdaemon tag 0.0.13.
17-08-27 12:21:38 ERROR (SyncWorker_19) [hassio.dock.interface] Can't install e5829d31/armhf-addon-appdaemon:0.0.13 -> 404 Client Error: Not Found ("repository e5829d31/armhf-addon-appdaemon not found: does not exist or no pull access").
17-08-27 12:22:48 INFO (SyncWorker_4) [hassio.dock.interface] Pull image e5829d31/armhf-addon-appdaemon tag 0.0.13.
17-08-27 12:22:50 ERROR (SyncWorker_4) [hassio.dock.interface] Can't install e5829d31/armhf-addon-appdaemon:0.0.13 -> 404 Client Error: Not Found ("repository e5829d31/armhf-addon-appdaemon not found: does not exist or no pull access").
Any idea what I’m doing wrong?
Thanks in advance!
Update:
I solved the problem but I still do not know what was wrong.
Here is how it worked out for me:
- Deleted vkorn/hassio-addons from the Add-On Repositories
- Saved and updated the list of all repositories
- Readded vkorn/hassio-addons
- Saved and updated the list of all repositories again
- Tried to install and volla! Hassio didn’t have any problems any more to find it
Now it is installed and works without any problems again.
