Dears,
I have a great problem with this board, because I’m not sure about waht type of bnorad I need to select in ESPhome in order to flash.
The board is:
https://www.amazon.es/gp/product/B08TBPBJGV/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Thanks a lot,
mcarty
(Arturo)
2
It look like a clone of Wemos Esp32 D1. Test with wemos_d1_mini32, I have one similar.
I have the following erro when flash (esp32 connected to my local computer, not the Interl NUC with home assistant:
![image](https://community-assets.home-assistant.io/original/4X/0/8/6/0860a6ed9dad6bb8996aefa1e54ff4f8cd24c423.png)
Any help please?.
Thanks in advance,
Jose
rudy12767
(Rudy12767)
5
Could be a driverproblem. Try restarting your PC or reinstall the driver.
I restarted Windows 10, and it continues with the same problem. It’s impossible to flash the esp…
mcarty
(Arturo)
7
I have some esp32 that the only way to flash them (the 1st time) was pressing the boot button.
when is necessary to press the boot button?, only 1 time at same time that press the esphome option to install?
keep the button pressed while plugging it into the usb (giving it power)
Finally worked with the folling configuration:
esp32:
board: wemos_d1_mini32
framework:
type: arduino
But it worked with another same board, I think that the first one have a brick and I don’t know how is possible to solve a brick in an ESP board…
Thanks to all for the help.
Jose
You would be the first one on earth being able to brick a esp in software, congrats!
I tried everything but only found hardware solutions to brick esps (providing 5V to the 3.3Vin Pin works good!) ![:brick: :brick:](https://community.home-assistant.io/images/emoji/twitter/brick.png?v=12)
